Turbo crossover and radiator fans
Old Dec 18, 2017 | 08:43 PM
70c10's Avatar
Default Turbo crossover and radiator fans
Hey guys long story short I got a hole in my radiator and the one I bought 4 years ago is no longer available. I ended up going with a nice aluminum Griffin with 16" fans made for an LS swap. Only problem is the fan is only an inch or so from the driver side crossover piping. I might be able to modify the radiator support to get another 1/2" or so. Do you think this will be an issue? The piping is wrapped with DEI lava wrap. I was thinking I could add the DEI heat shield for extra protection. Any thoughts?
Old Dec 18, 2017 | 08:56 PM
3 window's Avatar
Run it. Mine’s that close at one point. You’ll be alright
Old Dec 20, 2017 | 10:03 PM
70c10's Avatar
I'm going to see if I can get a little more room out of it somehow.
Old Dec 21, 2017 | 05:21 AM
lemans1's Avatar
I would run it too. If you can get the clearance, fine, but I ran mine for 2 years on the street like that with no issues.
Old Dec 21, 2017 | 08:22 AM
rt338b's Avatar
I would make a heat shield for it as I had a fan go out on mine during Dragweek last year by being that close. Dont know if you will be driving couple hours at a time steady at 50mph but after I made the shield it solved that problem.
Old Dec 21, 2017 | 09:03 AM
70c10's Avatar
The truck is just a weekend cruiser. The crossover runs below the fan motor. I was worried more about the fan housing melting. I've got a little more then a finger gap now that it's mounted.
Old Jan 3, 2018 | 03:47 PM
70c10's Avatar
I could use my old shroud and fans with the Griffin radiator but I have a question. They sell the same unit without the fans. One problem it's about an inch short on both sides of the core and sits about a 3/8 of an inch off of the core. Do you think this will work? I was told the shroud should cover the entire core.
Old Jan 3, 2018 | 06:05 PM
3 window's Avatar
I’d be more concerned with it not being sealed to the core rather than not covering the entire core. Get some sort of rubber seal to seal the shroud to the core and run it.
Old Jan 3, 2018 | 06:19 PM
70c10's Avatar
[QUOTE=3 window;19803850]I’d be more concerned with it not being sealed to the core rather than not covering the entire core. Get some sort of rubber seal to seal the shroud to the core and run it.[/Quote
The link doesn't work for some reason.
Old Jan 3, 2018 | 07:19 PM
truckdoug's Avatar
it's just a link to some push-on rubber weather strip edging.
I nab the stuff from the door openings of early 2000's hondas. works amazing.
