Building boost using timing retard with LNC-2001.
I went ahead and bought an LNC-2001 hoping I could get my GT55 to spool quicker on the brake by pulling timing. Any ideas on how much I should pull to begin with? I know it's better for manual cars, but I was told it can be done with an auto...
It spools in about 5 seconds at 4800 feet where I live, but when we got her up to Bandimere, with a DA of 8500, it wouldn't spool at all on the t-brake. I figured I'd try this out.
Also, have to maybe consider a stator change in the converter if it's still coming up slow.
I hope I can figure this out before May. I really don't want to see another 2.20 60ft time again. Lol.
So, I believe anything over 85kpa is boost here at 4800 feet...It's a bit lower at the track at like 5800 not factoring in the DA.
It's got 30ish degrees until 105kpa, then it drops to 26degrees until 110kpa, 22 degrees after that, and 20 degrees at 120kpa, which is 5psi factoring in the 85kpa atmospheric here in colorado. This is around 3400rpm. High 12's to low 13's afr until 105kpa, then mid 11's at 120kpa.
I think if all else fails, I'll remove a significant portion of the downpipe, seeing as it's v-banded together. That should help with spool.
