Gap the rings or send it?
Old Jan 17, 2018 | 12:26 PM
Turbo306Fox's Avatar
Default Gap the rings or send it?
Bought a gen4 6.0 shortblock and got quoted $600 to tear it apart gap rings and reassemble. Needless to say I'm not paying that for a $500 motor. Thinking about just throwing it in and crossing my fingers. Be about 15-18psi around 800whp. Who has had experience with stock gapped rings?
Old Jan 17, 2018 | 12:33 PM
svslow's Avatar
I didn't touch mine. Ran times in my signature on a 4.8
Old Jan 17, 2018 | 01:20 PM
brandon6.0's Avatar
If its a high milage unit i would bother with it. Ring gaps are usyally already opened up.
Old Jan 17, 2018 | 01:26 PM
47ford's Avatar
Do it your self? Takes a minimal amount of tools and just a little bit of time.... take the heads off, pop a piston out and measure the gap and you will know for sure instead of rolling the dice.....
Old Jan 17, 2018 | 03:10 PM
truckdoug's Avatar
Quoting someone $500 to gap some rings is a nice way for the machine shop to say " GTFO with your greasy SBE"
Old Jan 17, 2018 | 04:01 PM
ls3fox's Avatar
7 Second Club
my stock top ring was .006 27k mile ls3
Old Jan 17, 2018 | 04:54 PM
forcd ind's Avatar
Is it just a gap, or hone, clean, new head bolts, gaskets, etc.
Seems like a big liability for them if just gapping. I haven't had much luck with used motors, so I pretty much at least do a hone, re ring, look at everything.
Old Jan 17, 2018 | 05:19 PM
LLLosingit's Avatar
At $80 or more an hour shop rate take it apart gap the rings and reassemble is actually very reasonable.
Old Jan 17, 2018 | 05:26 PM
Bad Apache's Avatar
If it is a shortblock, you're already halfway there. DIY
And Force Ind, you're near me and I have to agree. Motors seem to be beat hard around here for some reason. And they are crusty/corroded from the road salt/pre-treat too.
Old Jan 17, 2018 | 07:37 PM
yenkomike's Avatar
I have yet to take any ls engine apart that did not need the carbon cleaned out of the rings . regardless of miles .
take it apart clean it all up and gap rings and you know what you have. its hard to tell what kills an engine that fails ring gaps or stuck rings from carbon= melted ****.
Old Jan 17, 2018 | 10:04 PM
truckdoug's Avatar
Its been 20 years or do since I worked in automotive machining, but if it took me 6+ hours to gap some rings I'd have been beaten about the face and neck with a mag base dial indicator
Old Jan 17, 2018 | 10:29 PM
MY_2K_Z's Avatar
Lol, but I'd definitely gap the rings my ly6 had gaps of .0012
Old Jan 17, 2018 | 10:45 PM
brandon6.0's Avatar
The original price quoted, is not tht bad. If u feel like u cant do it, then let them. A shop has to cover them selves if something happins or comes up in the process. Plus gaskets etc.
Old Jan 17, 2018 | 11:45 PM
LLLosingit's Avatar
Well I assume there will be a small parts bill on top of the shop labor. Most shops use book labor. It may take 3-4hrs but if calls for 6 that's what they will set the price at.
I could do a heater core in a Lincoln Mark 7 in 4 hours tops and book said 10hrs.... Do you think they only charged the customer for 4 or 10?
Old Jan 18, 2018 | 01:05 AM
1FastBrick's Avatar
Just run it. If the tune up is spot on you will be fine.
I bent 2 rods when it overboosted and the pistons were clean when they came out. I would have re-used them if they didn't hit the counterweight.
Save the cash in case you need a rebuild later. or put it towards other parts.
Old Jan 18, 2018 | 05:30 AM
jimmyg's Avatar
This ^^^.
Old Jan 18, 2018 | 06:03 AM
alocker's Avatar
+another. These engines are oil suckeres. My 39k mile Ly6 was squeaky clean inside except for the ring lands. They were caked and every ring was basically stuck. It takes time to clean everything and gap properly so the quote isn't bad but you can do it yourself. You will only have gaskets and bolts plus time. For every Jy build that makes it past 500 miles there is one that didn't ( totally made up stat but I prefer piece of mind).
Old Jan 18, 2018 | 06:18 AM
truckdoug's Avatar
but machine shops don't run on flag hours, they bill actual time.
at this point i'm just arguing for arguments' sake.
but i get where you're going. $500 is actually pretty cheap for someone who won't doesn't possess the skill or the tools to do it themselves.
and like many other's have said, the ringlands get gummy real quick in these engines.
Old Jan 18, 2018 | 11:30 AM
brandon6.0's Avatar
u can fix gummed up ringlands by soaking each piston over night in some diesel or atf. pour it in on top of the piston and let it sit. Ive used this before with success!
Old Jan 18, 2018 | 12:08 PM
tblentrprz's Avatar
6.0, sounds like you soaked with pistons still in bore? Did you remove pistons to assess how clean and free the rings were?
