WS6 w/ Powerdyne supercharger (new updates, blower mounted)
I picked this car up about a year ago. A true WS6 with an auto for 3500 bucks, running and driving. Not bad for around the NYC area. It had a multitude of issues but nothing horrible. I fixed every issue I could and took it to virtually every car show I could this past car season and it's been great, even with its mileage at 142K. This winter I decided it was getting some form of FI i just hadn't decided on what. After settling on supercharging I began looking for a Vortech setup since I had one on my Mustang and came up with absolutely nothing. So, I was just browsing the internet and found superchargerrebuild.com. They had Powerdyne brackets and I though eh, what the hell. I am good with fabrication and problem solving so i decided to go this route, against the opinions of the entire internet. I decided I could address the kits deficiencies to make it more reliable. Goal is around 400-430rwhp. I know that easily accomplished via heads/cam but I am bored and I wanted to build something different.
So fast forward to today. I have pretty much everything I need. I scoured the internet documenting the various problems and complainants with the kit as well as discovering my own. What I came up with was:
1. Cooling issues via Powerdyne’s fan setup
2. No info on pulley sizes that came with the kit (though recently I dug up an aussie thread stating the blower had a 3.47 inch pulley)
3. Classic blower issues (broken belts, bearings, over spinning)
4. Instructions are vague regarding kit parts, sizes etc.
5. Pulley is smooth and not ribbed due to replacing the idler pulley in the serpentine setup
My first issue was finding a blower which I wound up sourcing locally from a lawyer in Manhattan, a fresh built 928 blower with case venting, better bearings and the better belt. The blower is from a Mustang kit, so the volute is the 90 degree and not straight, but because I will be using my own plumbing, I think I can worth with it.
Next was finding a blower pulley that would work with this kit. The LS1 using that stock dampener @ 7.48 inches made it difficult because I needed a large pulley to keep from over spinning this thing. I wanted it around 38k, despite the better bearings. My original plan was a 2.9 pulley + an underdrive crank. Problem here was it would magnify the already crappy cooling fan issues with this kit along with charging issues with a cooling fan that draws a lot. So, I bought a 3.55 pulley and shaved the ribs off it which got me to a best of 3.26..ish inches. It still "over spins" to 42k but close enough. In the aussie thread I mentioned above, with a 3.47 he saw 5.5 psi of boost. I would hope to see 6 or 6.5 but I have a feeling I will fight a never ending battle with belt slip so we will see. More than likely I will switch to a 10% underdrive pulley by Powerbond in order to bring the RPM down a little and allow me to key the crank with ATIs kit. In addition, the instructions state to replace the stock tensioner with the one supplied in the kit. I opted for replacing it with the tried and true Buick pulley (larger and higher sidewalls for those who are not familiar).
For cooling I decided to go with the ATI shroud and a SPAL fan right off the bat. No cutting corners here. I got the 24XX cfm 16 SPAL fan in hopes that this will keep the temps at bay. I also will be using their relay kit for the fan. I anticipate with AC I will see issues, but I'll come back to that later when the car is moving.
The kit uses a draw thru MAF which I hate for plumbing purposes. Too much clutter. I am doing a blow thru setup and would like to mount a filter on the blower, but I am rethinking this now. Eventually I’d like to do meth and speed density so eventually this part will change but for simplicity, I’ll go this route via MAF.
Awhile back I robbed a junk Ford truck at work with a 7.3L diesel. I took the turbo and its 3-inch aluminum piping, including its couplers and T bolt clamps. Saved me a few bucks there. With its high mileage I decided it would be a good idea to replace valve springs so Ill drop some LS6 springs in there eventually. I have a set of rebuilt 706 heads sitting here which I kind of like the idea of (high compression, low boost). Maybe later. As an additional precaution or enhancement rather, and because the bolts need to come out anyway, I bought a 145 amp trunk alternator to ensure the fan gets more stable voltage. As of right now its winter and the car is outside so I can't really do much other than collect parts. I will update the thread accordingly. Forgive me in advance, i wrote this while on a train.
No intercooler as of right now. Eventually I will replace the maf with a screened pipe just in case an impeller disintegrates. At that point ill add a meth kit as well since I won't have to worry about a MAF anymore. I really like the idea of a 706 head/cam + blower and meth idea. If it proves reliable, ill give it a shot. Below are some pictures.
After fixing everything and taking it to a bunch of shows:
Thanks man! I know I'll get some flaming from the powerdyne but I have never seen one (and probably there is a good reason for that ha) but its not my daily or anything so if it breaks, it breaks.
I forgot to mention as well as of right now fuel is handled by FIC 42lb injectors and a racetronix 255. I will add the hotwire kit to the pump as well.
I bought these 706 heads awhile back, paid like 100 bucks for them and they are fresh. I figure that plus a good blower cam should be an interesting combo, well see!
What stall did you go with?
I am going to run a 3200 but seriously debating changing it to a 3600
The cam is the BTR LS3 Supercharged Cam and i was recommended a 3000 which i felt was too low.
As for fans I have not ran the car since I got the 16" and 9" spals mounted in the MM shroud. Its barely 30 degrees still in Iowa lol
Hello from NY as well. Westchester. I will never understand long islanders but Im sure the f-body force is strong out there.
Curious to see how this turns out. Its ambitious, and my concern is that power wont be where you want it. Coming from the 5.0 Mustang days, powerdyns were pretty un-impressive. I'm not knocking you, but I'm wondering how a blower that might add 30% to a 225fwhp motor is going to work on a 300+fwhp motor.
Looking forward to results and best of luck!
The XB are the gear driven units. This is a belt drive unit redone by 928 with the better bearings and more then likely a kevlar belt (though i believe continental makes some better belt for them now thast 928 uses). Mine is rated to 46k rpm wise but i wouldn't dare go near that. Mine should spin around 419XX rpm, slightly above the peak ceiling on a stock blower. I like it because there is no oil to run on these. I may even try their forced air bearing cooler since its the main reason they fail. Anyway the XB is always an option as it will bolt into my bracket without any modifications.
However, if the unit proves reliable, i may go the superchargerrebuild route as they offer S, T and YSI trims for this blower now. As it sits the blower is rated at about 800CFM. They claim 1200-1400cfm from the better trims so we will see.
The main drawback to this kit. It places the blower down low in place of the idler by the alternator. There is a solution to it if it becomes a problem though; 928 can "surgrip" the pulley I have. Its a coating they do to it to reduce belt slip. Haven't seen much in regards to customers using it though. I think its fairly new. This is also why i didn't want to use the 2.9 and an underdrive, I need the larger pulley for better belt wrap.
