Solid State Relay Experts - Please Come In
Old Feb 12, 2018 | 07:43 PM
2JZFC's Avatar
Default Solid State Relay Experts - Please Come In
Not sure if this is the correct forum but feel this will get more attention here.
I am using a solid state relay (SSR) with MS3X for alky injection control. I am pulsing the neg side of the alky pump and have the SSR wired as follows. 1 to a good ground, 2 to the alky pump neg terminal, 3 to the MS PWM and 4 to sw12v. In MS test mode, it works as desired with different PWs and I used it yesterday for the 1st at the track and it appears to have worked as the IATs dropped considerably and the tank level was down.
Now for the problem I am having. I have 2 FP relays next to the SSR and from the SW12V wire that goes to the alky pump + terminal, I have a tee that branches out to the 86 terminals of the 2 FP relays and the SSR 4. Refer to wiring diagram. Prior to yesterday, with the alky OFF, the engine ran flawlessly. However, yesterday with the alky ON, the power felt off and in the datalog, the FP readout looked like an oscilloscope on steroids, fluctuating from 62 to as low as 40 at 19psi boost. From what I can deduce, the problem seems related to the SSR because it starts at about 13-14psi boost and I have the Water Injection control enabling at >70% / 3800 RPMs / >169kPa. Had wheel spin soon after the launch and had to pedal it and between the time I got out of the throttle and the boost coming back up, the FP readout went back to normal then back to crazy for the rest of the pass when the boost came back up and then back to normal at the end of the pass.
Only thing I can come up with is that the sw12v that connects to the SSR 4 has feedback that is possibly also pulsing the FP relays. Just my own theory but would appreciate any feedback.
Old Feb 12, 2018 | 08:59 PM
truckdoug's Avatar
try switching to a FP relay that has a flyback diode built in
Old Feb 12, 2018 | 09:01 PM
truckdoug's Avatar
i use these ones https://www.delcity.net/store/Relays...xoCSWsQAvD_BwE
Old Feb 12, 2018 | 10:01 PM
2JZFC's Avatar
THANKS! I'll give them a call tomorrow to see if they have the ones with a mounting bracket.
Do you think the noise is coming from the SSR or the alky pump?
Old Feb 12, 2018 | 10:13 PM
JoeNova's Avatar
Restricted User
I end up with some super weird grounding loops or something when I ran the ground for my alky pump and the ground for 2nd fuel pump relay through a hobbs. My 2nd fuel pump relay would run full time instead of just priming with key on and then it would stop working when the hobbs switch turned on the meth pump.
Old Feb 12, 2018 | 10:19 PM
2JZFC's Avatar
I hear you. Not only am I going to get the relays with the diodes, but I am going to separate the wiring for the fuel pump relays from the alky stuff.
Old Feb 14, 2018 | 02:43 PM
stevieturbo's Avatar
Some SSR's will need a 1k resistor across 3/4
And you will likely need a flyback diode across the alky pump too.
File Type: pdf
Old Feb 14, 2018 | 08:05 PM
B18B1LS1's Avatar
I ran into a weird ground backfeed as well, running a 2nd 450 and my water pump through a Hobbs. Added some diodes and all is well.
Old Feb 14, 2018 | 09:16 PM
2JZFC's Avatar
Thanks! Have a couple of questions.
- Will a 1/4-watt resistor work for the SSR?
- I am assuming the diode goes between the alky pump + and - wires. Does it matter where I put it (close or farther away from the pump)? Does it matter which direction the diode is position? Do you have a specific diode recommendation?
Thanks, again.
Old Feb 15, 2018 | 05:59 AM
I dont think the resistor needs to be a high rating at all. And not honestly sure what it's function is, but I've seen a few places say it is needed.
Diode would be across +/- terminals of the pump, and AFAIK yes closer to the pump the better.
Diode is to allow flyback current to free blow back around the pump circuit so it would be in the direction neg to pos. ie.
As for type, I see many mention 1N4007, although I really dont know a lot about them.
I did use a diode on mine, but damned if I can recall what part number. I had issues and blew up my SSR and thought it was diode related, but turned out when I heat shrinked the diode/wiring the insulation had melted and the leg of the diode shorted on the wide.
I used a diode like this after that
http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
I did buy both of the above, but damned if I can remember which one I actually used and it's all heat shrinked up so cant even check. I've just been running it with the SSR as off/on though, as other issues prevented me PWM'ing things because of how I'd wired my turbo oil scavenge pump.
But I'm switching to in-tank pumps now, and will re-arrange wiring so I can PWM these without it affecting the scavenge pump. It'll probably be a week or two though before I have that finished.
Old Feb 15, 2018 | 06:44 AM
ddnspider's Avatar
^That resistor is limiting the overall current in the circuit if its implemented how that pic is drawing. Assuming the L is your pump, its also limiting the power to the pump, which seems odd. I would have expected to see the resistor in series with the diode and not in series with the parallel L/D.
Old Feb 15, 2018 | 06:50 AM
I think I seen some mention the resistor can also offer protection to the ecu in the event of a problem with the SSR.
Resistor across the control side will in no way affect power to the load.
Old Feb 15, 2018 | 08:22 AM
ddnspider's Avatar
Mfrom the drawing I didn't realize you're switch was on the control side, agree with them being isolated. In the event of a short of the control side of the SSR, the resistor would prevent a direct power to ground short since the SSR would have no impedance.
Old Feb 15, 2018 | 08:33 AM
2JZFC's Avatar
Thanks, guys.
Old Feb 15, 2018 | 02:58 PM
RICE ETR's Avatar
Turbo Addict
Thanks for posting this. I am running a Goldbox with the same SSR for methanol injection. I haven't had any issues and all is working well but this thread makes me think I should install a resistor as well as a diode. Is there any reason not to?
To clarify, the resistor goes between the 12v switch side on the SSR and ground from Goldbox (signal out) to the SSR and the diode can go right off the wires of the pump (in the back of my car), shown as above from negative to positive?
Thanks in advance,
-Jrod
Old Feb 15, 2018 | 03:22 PM
ddnspider's Avatar
Thanks in advance,
-Jrod
Put the diode as close to the pump as possible and make sure its installed with its polarity opposite of the pumps polarity.
The resistor can go on either side of the control side of the SSR. Either from the SSR to ground or from the Goldbox to the SSR. This assumes the Goldbox is an active high.
Old Feb 16, 2018 | 07:39 PM
RICE ETR's Avatar
Turbo Addict
Thanks for the response. I thought the resistor connected the + to - of the control side to prevent a dead short if the SSR failed?
Old Feb 16, 2018 | 09:34 PM
LilJayV10's Avatar
Have you seen these? I don't know if it would help you or not. It's 80 amp and 4 channel. And can do any combination of the 4 as long as it's 80 amp.
https://www.msdperformance.com/produ...hes/parts/7564
We just ordered several of the MSD SSR to play with at work.
Holley also has a pretty sweet SSR that they sell for nitrous but can be used for a lot of other things.
https://www.holley.com/products/nitr...parts/15620NOS
Old Feb 17, 2018 | 04:41 AM
And that is what has been said above.
Old Feb 17, 2018 | 04:59 AM
MSD looks like a handy piece, although no mention of any PWM ability.
Holley not bad, although seems a very low current item. That'd really need one per pump in most cases.
