How Do I Figure PR for Turbo Maps ?
Old Jul 3, 2004 | 10:13 PM
MNC5's Avatar
Default How Do I Figure PR for Turbo Maps ?
I'm stuck... How does one figure the Pressure Ratio for the Vertical portion of a compressor Map ?
And once you know how to calculate it wouldn't you have to figure different PR's for each engine RPM and boost levels to really get any usefull info out of the MAP.
I've ordered a GT42 and am having second thoughts about it being large enough for my setup, which is a iron block 408 with 9 to 1 CR which made @ the Flywheel 505HP @5700 and 515TQ at 4600 NA. Dyno'ed it Wednesday. Thinking I'd want to run at least 18lbs of boost to be in center of the compressor map ...Any thoughts
Old Jul 3, 2004 | 10:44 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
You can use this link below.... It has what you are looking for.
http://www.forcedinductions.com/help.htm
Jose
Old Jul 3, 2004 | 11:38 PM
MNC5's Avatar
Jose
Thanks, but it didn't show me how to do the math...which is what I'm trying to do... Lots of helpful info though
Old Jul 3, 2004 | 11:52 PM
V8_DSM_V8again's Avatar
Thats some pretty cool info...
I am thinking of running two of these... I'll have to look up the closest engine to what I'm building and divide by 2 then plot...
That is some kick *** stuff... One of the best laid out sites I have seen for non import turbocharging..
This 408 should be close enough for Ripped..... http://www.forcedinductions.com/consumption408.htm
Old Jul 4, 2004 | 12:06 AM
red ws6 99's Avatar
Pressure ratio (PR) = ( atmospheric pressure + boost pressure ) / atmospheric pressure
atmospheric pressure varies with altitude, but at sea level its 14.7 psia
Boost pressure can be gauge pressure - what would read on a gauge
Hope that helps
Gary
Old Jul 4, 2004 | 12:13 AM
MNC5's Avatar
Hope that helps
Gary
That works... thanks Gary
Old Jul 4, 2004 | 12:25 AM
LS1TECH Sponsor
V8_DSM_V8again, let me know what motor you want added and I will add it to the site. I'm always looking for feedback from the turbo community. Thats what we are here for..
Jose
Old Jul 4, 2004 | 12:38 AM
MECHAM's Avatar
Jose
ls1 364 and 370
Old Jul 4, 2004 | 08:18 AM
Excal's Avatar
Pressure ratio = 14.7 + boost / 14.7 going by sea level.
Old Jul 4, 2004 | 09:58 AM
LS1TECH Sponsor
SC-MECHAM-WS6, I will add them this week in.
Jose
Old Jul 4, 2004 | 06:44 PM
I'm still working on the specs... Static displacement may be close to something already on there... Raised runner heads, huge valves and some other tricks will be the biggest differences... Right now i'm debating the merits of bore and stroke combinations.... With a turbo motor I'm thinking of not stroking at all and focusing funds on the heads, intake and bore since less exotic forged reciprocating assembly is cheaper.. There is reduced less stress on the rods decreased piston speed etc... All these are probably a good idea for an engine. Alot of boost is hard enough on the rods and pistons... no sense in making it worse with stroke... It will have a big fat powerband due to a wider RPM range... My last car had as late of spool up as should be run on the street.... Heh I actually turned on the rally ALS system on my ECU for a while.... Somehow bystanders thought it was interesting... I wonder why...
If it is a peaky engine you need a shift strategy to keep the rpms up.. If it is a "bottomy" engine you need to do it keep them down... If it has a big fat powerband you have alot more leeway.. I have driven cars like that... it rules..
Old Jul 4, 2004 | 09:31 PM
LS1TECH Sponsor
A good turbo motor rule of thumb is short stroke, long rod. With big cube motors lag is not much of an issue like it is on my DSM and MK4 Supra.
Jose
Old Jul 4, 2004 | 09:57 PM
I'm thinking 4.1 bore iron block Ls1 stock stroke...
Witha Scat center counterweight Procomp lightweight billet crank. Think High flowing components and the right cam... Adjustable shaft mounted rockers, solid roller... The works...
Old Jul 6, 2004 | 02:20 PM
LS1TECH Sponsor
SC-MECHAM-WS6, the engine charts you wanted have been added.
Jose
