NAPA 6637 Air Filter
Old Mar 14, 2018 | 01:24 PM
Shownomercy's Avatar
Man-Crush Warning
Default NAPA 6637 Air Filter
If you know old PSD, you are familiar with this filter.
Any thoughts on how well it would work on a 7675 turbo?
Old Mar 15, 2018 | 08:23 AM
rotary1307cc's Avatar
The filtering quality and efficiency will be second to none
But if all out performance it will be lacking a good bit
That filter is good for around 450cfm at 8" of depression iirc
It definitely won't let that compressor show even close to potential
As the restriction and depression level raises all it is doing is raising the pressure ratio of the compressor
Old Mar 15, 2018 | 09:10 AM
Man-Crush Warning
Yea thats kinda what I figured, ah well.
Other option is that filter the cummins boys love so much, but think that will be too low flow as well.
Old Mar 15, 2018 | 10:10 AM
jrtoffroad's Avatar
Agree with Rotary about that filter, but there are a bunch of other high flow options out there that mount the same: K&N, UNI, r2c, etc.
Old Mar 15, 2018 | 10:43 AM
Yup
The larger filter you talk about is around 650cfm at 8" IIRC, so yes not stellar
I have a twin turbo Cummins and I ran this larger filter. Quit a bit of depression amas I have the filter minder mounted
So I bought a larger AFE dry flow to try. Very compact for the flow potential
That breathed awesome but was not up to the task of actual filtering on a ride that is on gravel roads and dust. It showed fine dust on the inlet. I drop kicked that thing across the shop lol
I moved back to the bhaf and live with the restriction but get OEM filtering
I now use that old AFE on my car and that will keep up to a gt55 94mm mid upper 20psi and non difference with the filter on or off
Inna street car environment it filters well enough.
I'd never use a AFE, r2c, k&n ect on an harsh particulate environment though
Old Mar 15, 2018 | 10:49 AM
Man-Crush Warning
Which AFE filter are you using?
Old Mar 15, 2018 | 10:53 AM
Ha sorry that was more than 2 cents
This was the size of the AFE
Same filter but in car. With a crease from drop kicked lol
Old Mar 15, 2018 | 10:55 AM
I will see if I can find the pn. They have a ton of different sizes though. Just about anything
R2c has decent selection as well and equivalent of a dry flow
Old Mar 15, 2018 | 11:05 AM
svslow's Avatar
Got a PN for that AFE unit?
Old Mar 15, 2018 | 11:19 AM
I believe this one
https://afepower.com/afe-power-21-91...y-s-air-filter
Old Mar 15, 2018 | 12:03 PM
stoverz28's Avatar
Why the dry filter over afe's pro 5r?
R2C is no longer in business. I had always planned to buy one of their filters eventually but seems like I waited to long.
Old Mar 15, 2018 | 12:22 PM
I just hate oiled filters personally
Old Mar 15, 2018 | 12:36 PM
408GT's Avatar
Originally Posted by rotary1307cc
That's the same one I use too. I think Honk if Parts Falls off uses it on his which is where I got the idea from.
Old Mar 15, 2018 | 01:19 PM
Man-Crush Warning
That AFE is for a 4in inlet?
If that holds up with yoursetup, that sounds like an easy choice for my small T4
Thanks for the advice man
Old Mar 15, 2018 | 01:53 PM
That's a 5" inlet.
They have a ton of different options though. You can get a 4" very similar to that
Old Mar 15, 2018 | 03:07 PM
jrtoffroad's Avatar
They are still in business. I'm literally on the phone with them right now ordering a filter.
http://www.r2cperformance.com/
Old Mar 16, 2018 | 07:18 AM
svslow's Avatar
That's a 5" inlet.
Do you run that filter all the time?
Old Mar 16, 2018 | 07:25 AM
Man-Crush Warning
That's a 5" inlet.
Not much offered in the 4 inch range, maybe I will just run a reducer and run that 5 inch filter.
Overkill means power, or something.
Old Mar 16, 2018 | 08:44 AM
Here is some 4s similar
https://afepower.com/afe-power-21-91...y-r-air-filter
Old Mar 16, 2018 | 08:47 AM
Yes all time on the car
Boost doesn't budge with it on or off.
