ProMod chassis and a stock LS1?
Old 04-05-2018, 08:51 AM
Game ova's Avatar
Ls1 car..... 3650#. Pump gas on low boost.... Been 9 teens @150.
Old 04-05-2018, 12:43 PM
svslow's Avatar
~900hp, pump gas 5.7L ?
Old 04-05-2018, 01:12 PM
Forcefed86's Avatar
Did he have 4 fat girls in the back? I'm coming up with closer to 1000... lol. Sure not a common occurrence anyway!
Old 04-05-2018, 03:14 PM
Game ova's Avatar
It put down 735rwhp, not sure how much torque it makes. But yes, 5.7L motor. This car is what made me go ahead and do the th400 swap, it was slow just like mine..... even trapped the same when he still had the t56 in it. He ET'd better only because he's got a dana, 10.80 before the swap.
Old 04-05-2018, 08:13 PM
98redorangeta's Avatar
Strait methanol big *** turbo should be fun
Old 04-06-2018, 07:32 AM
Forcefed86's Avatar
Did you see On3 just came out with there big boy turbos? 94 and 107mm compressors with 103mm exh wheels and stainless housings. I'd like to see what one of those is capable of!
Old 04-06-2018, 08:54 AM
newschool72's Avatar
wow! I like the stainless v band exhaust. I wonder where they are measuring the turbine at ? I have a feeling its at the inducer. I wish they would give full turbine/compressor wheel specs instead of throwing one number from each at us. They have an 80mm also. Its got a "96mm" turbine with the stainless v band too. Thst sounds like a borg copy , 96/88.
Old 04-06-2018, 09:12 AM
Forcefed86's Avatar
I’d bet it’s similar to the precision 103mm wheel, which is the exducer.
Diameter measurements are goofy too. Since a billet “80mm” can have 2-3mm of extra blade length stretching towards the hub. So is their 94mm billet version an exact clone of their cast unit? Or is the blade length longer as is the case with all these performance “class legal” turbos with tiny hubs and longer blades. IF the dimensions are the same, no advantage to go with billet that I’m aware of.
Old 04-06-2018, 09:38 AM
Restricted User
JoeNova's Avatar
I've been trying very hard to not start a build around one of these. I have 4 of my own cars to finish this year already.
Old 04-06-2018, 09:57 AM
Forcefed86's Avatar
I’m worried trump tax is gonna jack the china turbo price way up. Tempted to buy one just to have as a spare. Figure if they aren’t ticking time bombs, resale shouldn’t be a big issue anyway. Foot print looks smaller than a typical S400 T6 frame. Wondering if it would drop right in place…
Old 04-06-2018, 10:05 AM
Restricted User
JoeNova's Avatar
With a V-banded turbine inlet, I don't think a drop-in is going to happen.
Old 04-06-2018, 10:19 AM
  #32
Forcefed86's Avatar
Just meant space wise… I can cut a flange off quick! Those exhaust housings look pretty compact.
Old 04-06-2018, 11:33 AM
  #33
I would really like to see some side by side looks against something like their 88/83, or my 80mm GT45R china job.
Old 04-06-2018, 12:02 PM
  #34
Restricted User
JoeNova's Avatar
Their 88mm is a small turbo. Smaller than an S475.
Old 04-06-2018, 01:22 PM
  #35
Yea, my gt45 is a little bit smaller than the s475. I would just like to see some side by sides to see how big a difference the on3 version of the "big frame" turbos would be.Isnt their 88/83 suppose to be s rough copy of the PT88 ? Im sure the Precision version is probably noticably larger than the on3 88. Just courious about how much more realestate that 94mm would demand.
Old 04-06-2018, 01:55 PM
  #36
jordoza's Avatar
Well i was bored so with some common sense detective work (i checked the website) it says the intake is 5 inchs and the outlet is 3 so i did some measurments on the pictures i found did the ratio thing and compared to my s480s and it is pretty close compressor side wise. The turbine side is a mystery cause i couldnt find a direct or even close to direct on picture of it.
Old 04-06-2018, 02:05 PM
  #37
jordoza's Avatar
All that only works if the intake is really 5 inchs. Which i rounded up to 5.5 cause if the inside diameter is 5 then with the lip on eaxh side it should be around 5.5. The picture thing isnt exact but it should be within .5 inchs or so.
Old 04-06-2018, 04:57 PM
  #38
7 Second Club
ls3fox's Avatar
oh man why'd you have to show me this now i want one lol
Old 04-06-2018, 06:07 PM
  #39
jordoza's Avatar
I probably would have jumped on the 107 if they were out before i bought my s480s
Old 04-09-2018, 09:47 PM
  #40
codyvette's Avatar
We made a tiny baby smidge of progress tonight. This may take a bit. The owner is not a mechanic but his dad is. Do you guys think this new On3 turbo is good for this application?
