Holley tune for 5.3 with S480
Any E85 5.3s with an S400 turbo out there with an available tune? Just want to get an idea of where I need to be as I know all engines are different
If you're going to try to use the whole tune you have to make sure you go over it with a fine tooth comb to make sure you change everything over to your configuration. It's setup with one Bosch 02 sensor and not an NTK so make sure its correct before you plug in the sensor you plan on using.
http://www.nzefi.com/bosch-lsu-wide-...-applications/
