Turbo Ls e85 afr and timing
Old May 2, 2018 | 04:57 PM
Tss4.8's Avatar
Default Turbo Ls e85 afr and timing
New to the turbo ls, just wondering what some of yall were running for air fuel and timing under boost.
Old May 2, 2018 | 06:46 PM
truckdoug's Avatar
Currently running about 60% ethanol on 10psi and 15* and my target afr on the gas scale is 11.5. I'm told this is conservative.
Old May 2, 2018 | 10:31 PM
lmt0705's Avatar
11.3-11-5 afr, up to 22 degrees of timing. Made 1462@25psi. E85 likes to be a little richer then gas so low 11s is good. Part throttle and idle is best at high 13s low 14s. You could definitely throw more timing in there
Old May 3, 2018 | 12:39 AM
truckdoug's Avatar
yeah i noticed its smoother at idle and off idle a little fatter than i would with gas. i also pulled some timing at idle to keep some heat in the motor. it likes about 19* idling at 700 (baby cam)
Old May 3, 2018 | 09:54 AM
Tss4.8's Avatar
Thanks alot and when y'all say gas scale do you tell the computer you are running on gasoline and then use like 11.5 afr?
Old May 3, 2018 | 09:57 AM
Tss4.8's Avatar
Because I have the holley dominator efi and I have it set on e85 with 9.7 afr at idle. All help is appreciated!!
Old May 3, 2018 | 10:20 AM
3 window's Avatar
Set it to “gas AFR” unless you’re going to use the actual AFRs for E85. If you’re more familiar with gas AFRs, it’ll be easier to tune/understand. It’s all off lambda anyway.
Old May 3, 2018 | 10:25 AM
MY_2K_Z's Avatar
+1 I do the same, a lot easier to keep things straight in my head this way lol.
Old May 3, 2018 | 11:54 AM
badass68's Avatar
I run 16* at 20psi @ 11.2. This is still conservative though.
Old May 3, 2018 | 12:05 PM
svslow's Avatar
On my 4.8 I ran 15-16* on 25psi, and it could have used more.
Old May 3, 2018 | 01:18 PM
Forcefed86's Avatar
Whats bad about these threads is you can have 5-6* of variance in the timing. So if you have not mechanically verified your timing and sync'd that to your ECU... using someones else's numbers can be dangerous.
An indicated 15* on my timing map may only be running 10* actual timing. Then if I plug my 15* number in another engine that reads 6* high, that 15* indicated on the timing map may be 21* actual.
Unless you know your map and the persons timing map you are borrowing from have verified the timing and SYNC'd it 100% correctly... The only right answer is to start at something stupid low like 10* and read the plugs
Old May 3, 2018 | 01:48 PM
3 window's Avatar
Agreed with above on all counts. Read the plugs.
Old May 6, 2018 | 11:01 AM
Luke19901's Avatar
depends on exhaust flow and exhaust manifold back pressure and static compression ratio. ill give example for a single turbo with excellent flowing exhaust manifolds and turbo turbine set up. the example will be E85 at 20psi boost on 6.0/6.2 square port heads.
static comp timing
8.1:1 12.0AFR 20psi 16degrees (would likely take 20deg) 1000rwhp
9.1:1 11.5AFR 20psi 14degrees (would likely take 16 deg) 1000rwhp
9.5:1 11.5:1AFR 20psi 13 degrees (would likely take 16deg) 1000rwhp
10.1:1 11.2AFR 20psi 11 degrees (would likely take 14deg) 950rwhp
10.6:1 11.0AFR 20psi 13 degrees (lifted the heads and blew coolant out too much timing for combo) 1100rwhp
Old May 6, 2018 | 04:31 PM
3 window's Avatar
static comp timing
Where’d you come up with this???
Old May 6, 2018 | 05:03 PM
Luke19901's Avatar
picked 5 cars I’ve tuned with T6 flange Big single turbos, at the listed static compression ratios and told you how much timing I had in them and how much margin I “estimated” was left for additional timing
Old May 6, 2018 | 07:59 PM
MY_2K_Z's Avatar
Well I have 19* in mine and it seems to hold up well on sbe.
Old May 6, 2018 | 09:23 PM
CyberGrey Z28's Avatar
good info. Are these stock bottom ends/stock long blocks?
Old May 7, 2018 | 04:06 AM
Ben.'s Avatar
I had mine at 11.5 afr, 20* timing, 28psi, approx 1000rwhp. That was pretty much MBT. Funnily enough, I ran the same timing from 19psi and up. I later spoke to another tuner who has tuned a bunch of high hp stuff well over 1000hp and a couple over 1500hp. He said, if it's on E85 he punches in 20 degrees and goes from there, even on the stuff running 40+psi. Says thats just where turbo LS's like timing. I haven't done many but most of them have been around that.
Old May 7, 2018 | 10:20 AM
Forcefed86's Avatar
That’s ridiculous! Comments like that are why people blow their crap up left and right.
No motor (e85 LS or otherwise) “likes” a set amount of timing across the board. The charge temps, part combo, and fuel run will determine MBT timing. ETHANOL BURNS FASTER THAN PUMP FUEL, it generally needs less advance to hit MBT timing. While race gas many need much more. Guys that throw in hotter plugs and a ton of timing at E85 tunes don’t have a clue. Read the plugs, period. There is no other correct answer for a “street tuner”. Every combo will differ. I’ve run as high as 30* and as low as 8* on turbo tunes...
Experienced dyno operators/tuner can gauge when you are approaching the MBT timing limit without reading plugs... But most experienced turbo engine tuners won’t shoot for an MBT timing tune anyway. You don’t want giant cylinder pressure peaks near PK TQ. That’s how U detonate, bend rods, and blow head gaskets. Idea is to tune below MBT timing near peak torque to “cushion” the motor and keep cylinder pressure in check. Then ramp timing back in slowly past PK TQ and pour on power in the upper RPM. “Race” stuff usually stalls past 5k and bleeds off a ton of compression at lower RPM with a huge duration cam. So it will have a much more aggressive timing map in general.
Old May 8, 2018 | 04:22 AM
Ben.'s Avatar
Sorry mate, didn't mean to upset you, but I think what I've said has been miss interpreted. I was referencing e85 specifically, things are very different for pump obviously. I wasn't saying to punch in 20 degrees and that's the right number, but it's generally in the ballpark, and only a starting point. As opposed to pump where you might start out at a much lower boost number with 10 degrees and gradually sneak both up. For the most part I agree with just about everything you've said. The only other thing I will note which you didnt touch on specifically is EGT. There are instances where you may run a few degrees of extra timing, despite not picking up power, but to see a reduction in EGT. This is obviously on motors that have been built to handle high cylinder pressures (and I guess kind of covered under under your comment of reading plugs)
