Intercooler size/cfm question
Old May 8, 2018 | 02:40 PM
The0nlyon3's Avatar
Default Intercooler size/cfm question
hello, I have a 67 Chevelle with a forged 5.3 backed by a th400. I have a 80mm turbo and I don’t have a meth kit. The turbo is running off the WG which has the 14psi springs. What size/cfm intercooler should I be looking at? I’m looking for 650-700rwhp.
Also, space is limited. I could probably fit a 3” thick 24”x12”
anyway, this is my first boost build and I’m learning as I go along
Old May 8, 2018 | 02:49 PM
Forcefed86's Avatar
Don’t sweat it too much. Go with the biggest you can fit and the best core you can afford. Stay away from china cheapie intercoolers if possible. Garrett/Bell have some of the best and Treadstone is a middle ground between the cheap and expensive stuff.
Old May 8, 2018 | 03:01 PM
The0nlyon3's Avatar
Okay thanks, I’ll check them out. I’ve heard of a few people running the 4” wide IC from eBay with good luck. Thoughts?
Old May 8, 2018 | 03:06 PM
Forcefed86's Avatar
Just depends on the budget and what you’re looking for. Typical 31”X4”X12 (or the 3”) Ebay special is garbage as intercoolers go. Doesn’t mean guys haven’t gone really fast with them.
Old May 9, 2018 | 04:11 PM
stevieturbo's Avatar
As big as you can fit....it's as simple as that.
And as above, a good IC really isnt a huge pile more expensive than a **** one.
Old May 21, 2018 | 06:44 PM
The0nlyon3's Avatar
Ended up going with the Treadstone TR1045 (10” tall 4.5” deep)
Old May 21, 2018 | 06:59 PM
Nothing wrong with that !
Old May 22, 2018 | 08:12 AM
Forcefed86's Avatar
Thats what I use as well. Difference between the ebay IC of similar dimensions was huge on my setup. About a 40* drop in IAT and I picked up boost with less pressure drop across the core.
Old May 23, 2018 | 04:24 PM
The0nlyon3's Avatar
That’s good to know, I am glad I didn’t waste my time with the eBay IC.
