Which Gauges
Old May 9, 2018 | 10:52 PM
codyashby21's Avatar
Default Which Gauges
Hi guys, I'm looking into going to a twin turbo setup from my current supercharger setup. My question is this I currently have a Fuel pressure gauge, trans temp gauge, and air-fuel ratio gauge is there any gauges I should get rid of that are not really necessary?
Old May 13, 2018 | 12:23 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Your need for gauges is very subjective, and subject to the realities of your build. Once your package is complete, the only gauge you should need is a speedo, and if manual transmission, a tach. The reality is that none of us ever truly believe our builds are perpetually bulletproof, so we gauge the most likely points of failure. There are as many thoughts on the best way to do this as there are people.
Old May 13, 2018 | 03:57 PM
NSFW's Avatar
I've found AFR to be very useful for troubleshooting. I ignore it 99% of the time, but if the engine starts running poorly it helps a lot to know whether the AFR is in the ballpark, or too rich or too lean. I haven't had fuel pressure gauge before but there's been a couple times I've wished for one.
Old May 13, 2018 | 04:00 PM
MY_2K_Z's Avatar
You ignore your age gauge? I watch mine like a hawk. I wouldn't drive my car without it.
Old May 13, 2018 | 04:31 PM
jimmyg's Avatar
I broke down on the hyway the other day. Couldn't figure it out till I looked at my fuel pressure and noticed I had 4 lbs. lol
Fuel pump fuse went . I like to keep an eye on oil , fuel and AFR . Good for piece of mind
Old May 13, 2018 | 04:50 PM
NSFW's Avatar
My plumbing is solid and has been for a while now, so if the engine is running right it's not going to tell me anything I don't already know. I only check it AFR when I'm tuning or troubleshooting. And for tuning, data logs are far more useful than glancing at the gauge while driving.
I don't have one in my Corvette yet, but I've only had the car since spring. It'll definitely get one before I start adding power.
Old May 13, 2018 | 06:25 PM
dlandsvZ28's Avatar
No boost guage? Would think you would want one for sure.
Old May 14, 2018 | 10:41 PM
I didn't put the boost gauge because that is a given, was curious about the other gauges.
