Misfiring! Need Help!
Old Jul 6, 2004 | 05:33 PM
ss2000ls1's Avatar
Default Misfiring! Need Help!
I have NGK TR6 plugs with MSD wiring and the plugs are gapped at .035.I have a 6psi PD supercharger on it. When i started it up i keeps getting misfires. Is the gap ok for this setup or do i need to change it and if so what to? Do i need to program it so i can run the plugs at these gap? need HELP!
Mods:
Hookers LTH and Y pipe
SLP loudmouth Exhaust
Powerdyne 6psi Supercharger
Old Jul 6, 2004 | 06:07 PM
White_Hawk's Avatar
That's the same plug and gap I had on my PD setup with no issues. It is probably something else.
-Geoff
Old Jul 6, 2004 | 06:13 PM
WMSuperSport's Avatar
I'm having the same prob with cylinder #7. I'm going to check the plug wire, plug, and coil for proper spark. I don't know if your misfire is just on one cylinder or all of them but it might be some things to check out. ???
Old Jul 6, 2004 | 10:09 PM
MYTURBOT/A's Avatar
#7 is usually the first cylinder to let go so be prepared for the worse guys.
Also .035 is a little tight for only 6psi, I'd open the gap up to .040
Old Jul 6, 2004 | 10:21 PM
Hah, that's funny. I don't think any one cylinder is typical of "letting go" but I've never had an engine go bad so I'll keep you posted. I'll be prepared for a plug wire or a rocker arm at worst.
Old Jul 6, 2004 | 10:24 PM
TurboLT1's Avatar
Tenured Member
I have seen misfire directly relate to the cylinders that had cracked ringlands.
Old Jul 7, 2004 | 06:04 AM
2001WS6Vert's Avatar
That was my lucky number on my original motor. (melted piston)
Old Jul 7, 2004 | 06:48 AM
snkchrmr's Avatar
Same good luck here,cracked ring land #7 cylinder. Yeah from what I was told the #7 cylinder takes the most abuse from FI. Good luck
Old Jul 7, 2004 | 01:51 PM
MYTURBOT/A's Avatar
Mine was #7 also. must be a coincidence.
Old Jul 7, 2004 | 04:31 PM
MelloYellow's Avatar
I've heard #7 seems to lean out first due to manifold design.
Or maybe it is crank/TQ related?
Old Jul 7, 2004 | 05:01 PM
S_J_H's Avatar
Well I broke piston #3. So who knows..
