Melted a piston - unsure why.
Playing with the tune, I have actually run it even fatter...it woud simply misfire or just cut out completely.
Anyways, as mentioned I am not trying to debate what the more advanced tuners are saying here, just letting you know my expereinces.
Back in the day when I had my camaro, my WB would peg below 10.0 WOT and the more meth I added, the faster it got...so I'm not sure what's true haha.
With my POS stang on the dyno, rw went from 388 to 515 by leaning the AFR from 9's to 10.5-7. I only gained like 5hp going from 10.7-11.0-1. My car may be haunted.
- What is your full engine combo like compression ratio, cam specs, etc?
- What wideband are you using and where is the sensor located in your exhaust?
- What fuel injectors do you have?
- Post up your tune file and a log file since that will also help explain some things...
At a glance running 11-14 degrees of timing at 11 psi on 91 oct with a stock engine sounds like the problem if you were here in AZ, but it looks like you mentioned it had lower compression so that means it was a built motor and that would make a big difference so I just want to see more info to make sure I'm seeing the entire picture here.
Where is your wideband O2 sensor in your exhaust? Is it in the downpipe or in the hotside crossover somewhere? What does the rest of your exhaust after the turbo consist of?
IMO running the stock cam on this combo is going to make it VERY timing and heat sensitive, and I don't think the slightly lower compression is enough to get away with running that much boost on crap 91 octane.
Did you get the Deka 80s off of ebay or anything like that or did they come from an authentic reseller? Seen plenty of knock off chinese Dekas over the years that sell for only $250 a set and they are GARBAGE and have seen them take out more than one motor.
I just feel like 11.5 afr with 150* temps and maybe a little to much timing is my killer. Im going to switch to e85 to help that, but now Im starting fresh. Been reading a lot of e85 tuning and see you talking quite frequently, so I appreciate your input, all g with everyone else whose been helpful here
OK that's good but not sure that they flow match anything, I think they just resell what they get in boxes so with an injector of that size I would buy something that has been flow matched.
When genuine 80lbs are in the region of $60 each.....a full set for $250 ? Also has to raise some alarm bells. That's not just a little discount...that's half price. Or double what Chinese copies sell for when they're not pretending to be genuine.
https://www.siemensdekafuelinjectors...s-short-style/
I know the budget thing is cool and I ran cheap although genuine Siemens for years. But it is such an important area using known quality items here is essential
