Melted a piston - unsure why.
BTW, thanks for starting this thread. Great info being discussed as a result of your loss.
I have seen plug porcelain fall out once before with no signs of det evident when engine was pulled down. was a boosted application on pump gas. happened twice!!
assembled with identical components the second time round, flow tested injectors and they were within 5%. I threw them in the bin anyway and replaced them. ran flawlessly for the next 12 months until we snapped factory crankshaft. cause of that was square edge left when machine shop opened up oil galleries creating a starting point for a crack.
I don't use an egt monitor but I can report from experience that drive pressures don't change noticeably in relation to fuel quality. Only thing that changes IME is mechanical changes.
I have seen many pump fuel turbo LS tuned by guys with an import background come in running 10.50-10.80 AFR and about 4 degrees more timing than I would ask for. every one that ive retuned makes more power, more torque. the engines sound more crisp and rev cleaner and are more responsive on the road. all I did to them was come up to an 11.6-11.8 AFR and run timing I consider appropriate (ballpark 4 less than the import tuners file).
touch wood, theyre all still running
attached is a twin turbo SBE 5.7 on pump. "ovebang" file is from other tuner.
11psi93 pump 11.50 AFR 10 degrees starting to pull timing from 60 degrees C IAT
9 psi E85 11.80-12.0AFR 16 degrees starting to pull timing from 60 degrees C IAT
11psi E85 11.80-12.0AFR 14 degrees pulling from 60*C IAT
13psi 11.80 AFR 14 degrees pulling from 60*C IAT
also thank you for that Luke, I’ll go convert 60* c to F so I know what I’m looking at lol
