Breaking up in boost
Old Jun 30, 2018 | 10:48 PM
Kecrew's Avatar
Default Breaking up in boost
turbo 4.8 on 16 pounds ran flawlessly broke the trans and swapped from a 4l60 to a th400 now its has a misfire at 7 lbs have already replaced plugs, they're gapped at .024 only thing that has changed is the transmission and stall speed went from 3500 to 3200 have changed the crank sensor and was able to hit 11 lbs once
https://youtu.be/n4-pw-vyseU
File Type: mov
Old Jun 30, 2018 | 11:09 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Did you over rev the engine when the original trans broke? Could be a valve spring issue.
Old Jun 30, 2018 | 11:14 PM
Kecrew's Avatar
no I didn't it was driving fine when I came to a stop wouldn't pull anymore was shooting all the fluid out of the vent stall was destroyed as well
Old Jun 30, 2018 | 11:23 PM
gametech's Avatar
I'm guessing you had downtime between transmissions. Any wires get rodent chewed?
Old Jun 30, 2018 | 11:26 PM
Kecrew's Avatar
2 weeks checked all the harness don't see any issues
Old Jul 1, 2018 | 12:54 AM
gametech's Avatar
Out of ideas for now. Sorry.
Old Jul 1, 2018 | 06:58 AM
jimmyg's Avatar
No wires between the bell housing?
Old Jul 1, 2018 | 07:42 AM
chiaj144's Avatar
Plug wires, coils? Might not be related to the trans at all and just happened to occur at the same time.
Old Jul 1, 2018 | 09:44 AM
Kecrew's Avatar
no sir have checked it
Old Jul 1, 2018 | 09:45 AM
Kecrew's Avatar
checked all of that out just hard to think what could've happened to cause this all of a sudden
Old Jul 1, 2018 | 09:56 AM
3 window's Avatar
What ecu?
Old Jul 1, 2018 | 10:45 AM
Kecrew's Avatar
Originally Posted by 3 window
What ecu?
fitech ultimate ls
Old Jul 1, 2018 | 06:16 PM
jimmyg's Avatar
My buddy’s got a fitech set up on his sbc. He has had a few issues with it. I would give them a call.
Old Jul 1, 2018 | 07:49 PM
HydroStream6's Avatar
What plugs? Converter could be loading it differently.
