Turbo 5.3 with a Glide
Old Oct 15, 2019 | 08:29 PM
RonSSNova's Avatar
I have an opportunity to switch to a PG for free. Trans brake, billet input set up for the TH 400 converter.
Not quite free, will require a converter adjustment, and diff driveline.
From the truck I posted about.
Considering it
Old Oct 15, 2019 | 08:39 PM
stoverz28's Avatar
Anyone here use a gearvendors unit?
Old Oct 16, 2019 | 02:49 PM
68roadrunner's Avatar
i talked to them at hotrod drag week. definitely an interesting piece. Cost $3.5-$4k. I couldn't believe it. I'll pass!
Old Oct 16, 2019 | 03:00 PM
3 window's Avatar
Considering it
Give it a shot. If the converter’s right it’ll run. You’ll drop a good amount of weight also. The th400 is a pig compared to the glide.
Old Oct 18, 2019 | 01:51 PM
MIAmotorsports's Avatar
You talking 1/8 mile?
My example was 1/8th mile. Change the gear in the rear for the 1/4.. A 1.4 second gear leave will work for both. No different than a glide. 2 gears...
Old Oct 18, 2019 | 01:54 PM
you can find the used for 2500.00 They are good for highway driving if you have a low gear in the back. The shift too slow to use during a pass. I have one on my old tow rig...1997 f350. They are very reliable units.
Old Oct 18, 2019 | 01:58 PM
My t400 weighed 161lbs with convertor and fluid
Old Oct 20, 2019 | 07:19 AM
forcd ind's Avatar
I thought Stock48 ran a glide in his nova, he won Drag Week, and turned it up after
his final pass and went 8:19 or something. Was like on a set of rails. Myself I always
preferred a 3 or 4 sp for the street.
Old Jun 21, 2021 | 09:51 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Did you ever do the swap?
From following tons of 5.3 single turbo builds, a 1.8 glide + 3.50+ gear is preferred over say a TH400. Seems like for the TH400 setup, a 3.25-3.50 gear works but starting somewhere in the mid to low 8s the gearing starts to result in some power control issues. That said I did TH400 and a 3.50 out back, and I'd love to have that problem at some point.
Old Jun 21, 2021 | 10:50 AM
Black_Sunshine_99's Avatar
See I also did a TH400 / 3.50 gear combo on a big single 5.7.
I contemplated a glide for quite a while but kept reading about the SLR required to run a glide and according to the calculator a 3.50 and 28" tire theoretically wouldn't work yet all these guys are doing it.
Plus at the power level I was looking at being at, the glide would require an aftermarket case where as with the TH400 option I used a TH475 core with straight cut planetaries which saved quite a bit of money and has proven to be a reliable combo.
Old Jun 21, 2021 | 12:22 PM
LS1Tech Co-Founder
Yeah after doing more research, I found more friends running a TH400 and 3.25 combo. A good buddy ran down to 8.teens with TH400 and 3.50 but the SLR got problematic for him. I ain't even made a pass yet so it's a someday concern for me.
Based on the range of options, would be cheaper for me to drop down to a 3.25 than do a 2.10 gear set or a 'glide swap.
Old Jun 21, 2021 | 12:33 PM
  #32
3 window's Avatar
With any trans, the farther apart the ratios are, the more drastic your shift extension is going to be. So that’s something to keep in mind. Many are super fast with the Th400s, but I can tell you from personal experience that the glide is WAY easier to manage.
I run a 1.80 glide, PTC 9.5” 17-0 converter, 3.31 gear and a “short” 275/60 tire. If I shift at 6500, it goes into high at about 90mph. So it’s in low for about 4.5-5 seconds (on the street curve) which makes power management much easier. You run a taller tire than me, so your gear would obviously be lower to compare apples to apples. I have a 3.55 on the bench and know it would help it hustle a little better in high gear. This is just my experience, others may differ.
Old Jun 21, 2021 | 12:44 PM
  #33
LS1Tech Co-Founder
Good stuff. I'm currently on a 275/60/15 PBR but I think my long term term tire will be a 295.
I maintain a LS Record List in a group on FB (LSX Record List), and the 1.8 glide + 3.50-4.10 is very popular (rear gearing of course varies 1/8 vs 1/4).
Nailing the converter for 1.8 is something seems like PTC has done very well.
Old Jun 22, 2021 | 05:12 AM
  #34
yenkomike's Avatar
the 1.76 glide in my blue nova was a very good setup with a 3.42 gear and 275 pro tire .car was 3510 lbs with driver. street drove great and worked really well at the 9.0 - 9 teen power level 1/4 mile. very calm at the launch and worked better on a lesser preped track than a t400. the 2.48 first in a 400 takes a little more power management to get out of the hole im finding out with my buick. or go to a 3.08 gear.
Old Jun 22, 2021 | 12:28 PM
  #35
3 window's Avatar
I did a 3.08 with my Th400s for a while. It wasn’t bad, but driving around it hung on the converter WAY more than I liked. Went to the 3.31 and it was much better. Just FYI
Old Jun 22, 2021 | 02:24 PM
  #36
This is great info, for me I have no intention of getting into the 8.teens anytime soon so it sounds like I made the right choice for now.
The goal is pretty modest at mid to low 9's at 800whp on pump fuel and maybe 9.0 or 8.99 at 1K whp on race gas.
I looked at a second gear leave TH400 but the gear set and brake I would need were almost as much as what I spent on the whole trans with some good parts in it.
I still wouldn't mind knowing how guys are getting away with running such a low SLR with a glide and tall gears, I would have thought that would tax the transmission/converter too much and cause problems but obviously not.
Is the SLR just a guide and the problems come when it gets too high with traction limitations?
Old Jun 22, 2021 | 02:29 PM
  #37
When you say hung on the converter, do you mean it kept it in that range where it wasn't locking up and continuously slipping creating heat?
I've got a 3.50 gear now and was looking at 3.08 but you said 3.31 were better, just thought maybe that gear kept it closer to lock up.
Old Jun 22, 2021 | 02:43 PM
  #38
Ghost23's Avatar
This was an interesting read. I planned going with a 4l80, for the OD and lock up, in my Chevelle. I'm building a 6.0 with 7875 next gen billet, stock crank, forged pistons and rods, summit stage 1 ghost cam, LS3 heads. It was between a 400 and 4l80. I really hate how expensive a decent built 4l80 is. I still have the original powerglide that I swapped out back in 2000. My car won't see the track much. More of a fun street car. What are your opinion on the 3 transmissions for a street car? Is a powerglide really that much better than a 4l80 with OD and lockup, that can be controlled by Holley EFI?
Old Jun 22, 2021 | 02:57 PM
  #39
The 4L80 will handle some power with basic mods, a friend of mine put 700whp through one with just clutches and some valve body mods.
If you're looking for street and your combo will stay where its at then it would work, once you start getting into 1Kwhp territory it gets crazy expensive.
With that said, I had a TH400 built locally for 1,200hp for about $1,600 including sourcing a TH475 core.
My buddy paid $1K for a 4L80 which was basically a core since the builder did a crap job, then spent another $1,500 building it for 800whp, plus $800 for a decent lock up converter which would have been the same for the TH400. That doesn't even include all the misc. stuff needed to run the 4L80.
4L80's are hot right now and the parts are a premium, just gonna get worse as inflation on steel parts rises.
Old Jun 22, 2021 | 03:51 PM
  #40
Ghost23's Avatar
I'm not dead set on a 4l80. I have a powerglide that's been sitting for 21 years. If a powerglide or 400 works well with a turbo LS on the street, then I would go that route. Especially since they are much cheaper than a 4l80. I say "street" but it's a Chevelle with a turbo LS, eventually. So you can imagine how I'm going to drive it. Just like I did when I was 16! I've pretty much beat on the car for 26 years and don't plan on stopping. Spirited driving, not worried about fuel mileage or saving my tires, taking off quickly, hard tire barking shifts. Not grandpa in his vette or street rod going to the local cruise in. I've never drove a high horsepower fast car with a 4l80 or any other OD lockup trans. Only my diesel truck I used to have. Only 350, 400, PG, and manuals. I have no idea how a 4l80 will feel or how the power will be put to the ground.
