Turbo 5.3 with a Glide
I've got a 3.50 gear now and was looking at 3.08 but you said 3.31 were better, just thought maybe that gear kept it closer to lock up.
The goal is pretty modest at mid to low 9's at 800whp on pump fuel and maybe 9.0 or 8.99 at 1K whp on race gas.
I looked at a second gear leave TH400 but the gear set and brake I would need were almost as much as what I spent on the whole trans with some good parts in it.
I still wouldn't mind knowing how guys are getting away with running such a low SLR with a glide and tall gears, I would have thought that would tax the transmission/converter too much and cause problems but obviously not.
Is the SLR just a guide and the problems come when it gets too high with traction limitations?
The 1.8 glide / 3.50-4.10 combos tend to work great at the track. The SLR of a stock geared TH400 (2.48 first) needs more "tuning" to work when guys start to approach 8.00 from what I've seen, and overall that combo tends to be easier to work even for 9 second cars.
I like the TH400 because with a manual valve body there's no electronics, it simple and it shifts when I tell it to.
I copied the parts list for FTI's 1,200hp TH400 and pieced it together over time so I wasn't out a big chunk all at once.
Mine doesn't bark the tires or any of that nonsense, just a good firm shift so as not to upset the chassis and beat up the driveline.
If you can find a good TH475 core which are found in larger BBC equipped RV's and dump trucks, those come with straight cut planetaries which are stronger than the helical cut planetaries commonly found in the passenger/light truck transmissions, plus they whine loudly and sound really cool lol.
The main draw back is usually when you do a full manual valve body, that usually eliminates the ability to down shift which to me is not that big a deal but if you're really street focused you might find that to be a problem.
It seemed a lot more economical to go with an HD TH400 core and build from there instead of an AM PG case and what not.
Pick up a unit rated for 800whp from a known builder (Rossler, FTI, Jakes, etc.) since you'll probably never see more than that for a street cruiser and spend money on a good converter because the converter makes all the difference.
For the converter I'd recommend Circle D, they've been great to work with, PTC is also really good, FTI is good but pricey, I'm sure there's others who can make recommendations as well.
That's why the 4L80 is good, the shifts are controlled via solenoid and not by pressure so you can run high pressures for high horsepower and maintain automatic functions.
I'd ask a reputable builder what they recommend based on your power goals.
There are kits out there that make a TH400 manual and allow down shifting but my builder said even those aren't a good idea since they can knock the teeth out of the back of the case.
I can't speak to the glides, they may be different.
Aftermarket case, 10 clutch drum, input/output shafts, converter dump valves, etc.
It seemed like the PG needed a host of parts to measure up to a TH400 and cost considerably more.
At what power level do you see the factory PG case become a limitation?
I'd be curious to know what one would take to hold around 1,200whp in a street/drag application.
Raising line pressure is harder on the case, sometake it for a while & some don't. I've built a few for friends, usually using the good pieces they already have & making them better but
unless you can get some wholesale prices it's gonna cost more than an FTI glide or something similar. Mineis probably good for 1500hp, a bit more if the drum is upgraded with more clutches &
has cost roughly $4k. I can give specs if needed.
take it for a while & some don't. I've built a few for friends, usually using the good pieces they already have & making them better but unless you can get some wholesale prices it's gonna cost more than an FTI glide or something similar. Mine
is probably good for 1500hp, a bit more if the drum is upgraded with more clutches & has cost roughly $4k. I can give specs if needed.
Think I'll play at a lower horsepower level lol.
I think I'll end up playing with taller rear gear ratios first or perhaps picking up PG pieces here and there like I did with my TH400.
