BOV spring too stiff? VS Racing BOV
Old Oct 11, 2018 | 08:55 PM
TXjeepTJ's Avatar
Default BOV spring too stiff? VS Racing BOV
I have a VS Racing BOV, the soft spring would hold the BOV open at idle
installing the stiff spring, I notice a little turbo flutter when I let off at about 5 psi, letting off at 12 psi I don’t hear the flutter as much
is this ok? Or should I run the soft spring and just run the BOV open while at idle?
the flutter sound sounds like what a Supra BOV sounds like, but I can definitely hear it coming from the turbo and not the BOV
Old Oct 11, 2018 | 09:21 PM
3 window's Avatar
Shim or stretch the soft spring until the BOV stays closed at idle.
Old Oct 11, 2018 | 09:26 PM
TXjeepTJ's Avatar
Why didn’t google tell me this?? Good idea! Thanks
Old Oct 11, 2018 | 10:05 PM
slocaddy's Avatar
I'll have to try this with mine, it's not a vs, but same style bov.
Old Oct 12, 2018 | 01:08 PM
truckdoug's Avatar
I like to drive around with the hood off to make sure it's closed at cruise.
But then again I just like driving around with the hood off
Old Oct 12, 2018 | 03:59 PM
slocaddy's Avatar
I save 300 lbs driving without my hood
Old Oct 12, 2018 | 04:36 PM
DBRODS's Avatar
A stiffer spring will actually make it build boost faster too.
Old Oct 15, 2018 | 08:33 AM
TXjeepTJ's Avatar
Hmm, well I tried stretching the light spring. It just eventually loses it's length and the BOV opens. VS Racing says to use the stiff spring for LS engines. Maybe I need to lube up the BOV to make sure it can easily open?
Old Oct 15, 2018 | 10:02 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Can you put a smaller helper spring inside the light spring? You can probably source this from a decent hardware store, or shim it with a washer or two.
Old Oct 15, 2018 | 01:56 PM
TXjeepTJ's Avatar
I actually had a smaller spring, I think it was meant for the wastegate. I looked into doing what you said (doubling up the springs) but the smaller spring doesn't sit 100% flat and I feel like it may cause the BOV to bind up
