Boost And Timing
Old Oct 24, 2018 | 11:12 AM
TWIN NOVA's Avatar
Default Boost And Timing
I have a forged LQ4 twin 70s this is my first time tuning a boosted motor. The AFR is around 11.4 -11.6 on pump gas 12psi boost I don't have knock sensors so it won't pull timing. So the question is how much is to much when it comes to timing. What would be a good starting point. And is there a never go there point. Thanks
Old Oct 24, 2018 | 11:13 AM
MY_2K_Z's Avatar
What fuel are you running and are you running meth
Old Oct 24, 2018 | 11:17 AM
TWIN NOVA's Avatar
no meth most of the time 93 plan to go 100 if I go to track
Old Oct 24, 2018 | 01:31 PM
Forcefed86's Avatar
As much as it wants... This topics been discussed to death, might try the search.
The only answer worth a damn is to start out extremely low with timing, Set your max desired boost and square away the AFR. Then work your way up adding timing while watching the plugs. Any other suggestion is a total guess.
Old Oct 24, 2018 | 01:59 PM
ddnspider's Avatar
12.2685794655 degrees....or read the plugs.
Old Oct 28, 2018 | 04:32 PM
stevieturbo's Avatar
Advance it til it blows up, then pull back a bit.
Old Oct 28, 2018 | 08:14 PM
truckdoug's Avatar
i'd leave the spark NA until 105kPa and yank it down to about 10º when I hit 8-9 psi. maybe bump it back up after peak torque.
start conservative and read the plugs. the timing mark on the strap is very reliable way to see what the motor wants
consider spraying some water meth too. it can really add a margin of safety with pump gas. all it takes is one bad tank of gas and kablooey!
Old Oct 29, 2018 | 11:09 AM
Kfxguy's Avatar
Too funny!
Old Nov 2, 2018 | 10:10 AM
TWIN NOVA's Avatar
thanks
Old Nov 2, 2018 | 01:21 PM
TrendSetter's Avatar
i use the sloppy suggested rule of 14 degrees at 14 psi. seems to work fine. i believe im at 5 degrees at 22 psi.
motor is a 5.3 on 93
Old Nov 2, 2018 | 03:31 PM
ddnspider's Avatar
5....FIVE? What size turbo or weren't you running small twins?
Old Nov 2, 2018 | 05:06 PM
5deg is pretty low unless it's quite high CR.
Old Nov 2, 2018 | 07:18 PM
3 window's Avatar
5s just as dangerous as too much!
Old Nov 3, 2018 | 12:12 AM
Game ova's Avatar
EGT is probably like 3800, with 5 degrees of timing.
Old Nov 3, 2018 | 07:34 AM
twin 66s
i pulled up my last log and its actually 6.5 degrees at 22psi. i just recently upped boost from 18 and the higher end of my tables arent quite there yet so ¯\_(ツ)_/¯
what should timing be on a stock 5.3 at 22psi on 93?
Old Nov 3, 2018 | 01:20 PM
twin 66s
Whatever gives best power/torque without any risk of detonation. You'd need to tune it o a dyno to find out what it "should" be for your build.
Old Nov 3, 2018 | 01:26 PM
Kfxguy's Avatar
twin 66s
that sounds pretty low.
Old Nov 3, 2018 | 01:29 PM
Kfxguy's Avatar
I wonder if my 16 degrees at 6psi is too low. Seems like with nitrous you don’t retard it as much (what like 3-4 degrees per 100hp?) so maybe I really need to be around 18-20 at 6psi. And maybe go to 16 at 8 psi and 14 at 10.
Old Nov 3, 2018 | 02:08 PM
ddnspider's Avatar
twin 66s
What do the plugs look like? Stock cam and ~9:1 CR?
ddnspider's Avatar
What do the plugs look like.....broke record lol. Youre likely light on timing but read the plugs.
