Fox body LS turbo guys, come in!
Hey everyone, i am looking for some info on the following:
what accessories have you found work the best in these cars with turbo setups? as far as water pump, alternator, etc.
im also interested in what intake most guys seem to be running. i like the ls1/ls6. i see alot of guys with truck intakes, and some with aftermarket. post up and let me know what accessories and intake you are running!
any info would be appreciated, and keep a look out later this winter!
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
TWITTER @HURONSPEED
I run an F-Body spacing Dirty Dingo kit on my car, it works pretty well. Been on there since 2016. It uses a small case 105A truck alternator. Car does not have A/C or PS though. I have ran both an LS1 and Pro Flo intake, my combo really liked the Pro Flo. The intake swap gained me 3-4mph on the same boost in the 1/4.
Attachment 715976
Attachment 715976
I'm running all stock truck accessories, works great.
I also use stock truck manifold, the only way you can fit the truck manifold is by using AJE k member
Not quite a Fox, but similar: SN95. Overall fitment is pretty similar, but we may have a little less hood clearance than the Fox guys. If you're working on developing a kit for the Fox cars, you can probably cover us SN95 guys without too much more effort.
Truck PS and alternator. No AC. F-body water pump with some spacers. Stock truck accessory spacing, but aftermarket bracket (on driver's side) to lower the alternator a few inches for hood clearance. LS6 intake manifold.
https://ls1tech.com/forums/conversio...o-lq9-t56.html
we do! single T4 and twin T4 versions. we are doing a single T6 version this winter, and continuing with the twins!
thanks for the input everyone.
what would you like to see in a fox kit? we are doing as much market research as possible before we build the T6 prototype.
thanks again!
-Casey
thanks again!
-Casey
__________________
TWITTER @HURONSPEED
TWITTER @HURONSPEED
Looks good.I agree about the pas side is real tight and number 3 plug on mine is really tight but overall seems like a good kit.I just got mine fired up lastnight.I've got to get with lsxpowertuning and get him to help me on the tunning. Lsxpowertuning and Huron have both been very helpful and good to deal with.I bought my holley system from lsxpowertuning and he has been real helpful and hopefully I can get it tuned and exhaust on it and finally try it out.
i just bought a coupe car that has one of these kits on it. Seems really nice and the fitment is good, except the passenger side down pipe could be moved a little bit. It’s way to tight to the plug wires. Here’s a couple pics, and an idle clip. Has exhaust ran all the way to the rear ended with some cheapo bullet mufflers.
https://youtu.be/cHiCPMiDWeo
thanks for posting! we will definitely take that information into consideration.
-Casey
__________________
TWITTER @HURONSPEED
TWITTER @HURONSPEED
sbe ls2 with a BTR turbo cam. He wasn’t sure what stage on it. No. I got it from a guy in Memphis. He did buy it from his buddy that he helped build it in the first place. Not sure of his name tho. Is there any plans for offering a different style of down pipes? Like perhaps fender exits? Maybe utilizing the existing holes in the inner fenders that are directly behind the turbos? Also, what turbos would be a direct swap for what I have now? Something in a nice BW, or preciosion.
