Frozen boost type 12 intercooler
motor is just budget L33 with good pistons, LJMS cam, studded, billet BW 480 and BS3 ECM.
read some people see a 20-50 drop in IAT with bigger lines
from what I learned a higher end cooler like chiseled has a more efficient core like a bell or a garret and can use a 1" id line on the 1k or 2k hp models. On the cheaper coolers like the type 12 the cores are not as efficient coupled with fact they only have fittings for 3/4" id lines. Opening up fittings for 1 1/4" id lines help the cooler be more efficient.
5 gallon ice tank with rule 2,000.
It would start at 70 degrees on the line and rise to 130 iat at the end of the 1/4. Typically used half ice and water.
That's a great idea...thanks. That bung that's 3/4 npt that frozen boost put on is pretty think I may to find an 1 1/8 or 1/4 nipple that will fit or just do same as you.
BTW I asked in a PM but didn't here back. You guys tune BS3 at your shop in *******?
