Surge valve not opening
Old Apr 20, 2019 | 08:59 AM
forcd ind's Avatar
Default Surge valve not opening
Using the VS surge valve, it felt pretty stiff trying to push on it, with the engine running,
12-13" of vac, it doesnt open. It came with a second spring, but it felt stiffer. Anyone
ever just cut the spring until it could pull open with the vac. source avail. Not sure if there
is some other issue or just to stiff a spring. I had taken it apart and the piston seemed to
move ok.
Old Apr 20, 2019 | 09:01 AM
3 window's Avatar
BOV valve?
Old Apr 20, 2019 | 01:03 PM
forcd ind's Avatar
Ya, back in my Procharger days we called them surge valves, w/o one you sometimes
got a surging during cruise (blowthru carbs)
Old Apr 20, 2019 | 03:24 PM
3 window's Avatar
You dont want it to pull open with vacuum otherwise your pulling air through the cold side piping instead of the air filter. Find a spring light enough just to keep it closed at idle. If you snap the throttle, you should see it open briefly then close again. That’s how I set mine up. Been fine.
Old Apr 20, 2019 | 04:22 PM
stevieturbo's Avatar
He hasnt even stated the application, turbo or blower ?
Can you get it to open at all testing with a Mityvac ? Does it even move ?
Old Apr 21, 2019 | 09:53 AM
forcd ind's Avatar
Turbo-I hooked up a vac pump I got off an import, use it to bleed brakes. It can pull
over 25" of vac, the valve doesn't move. When I had it apart it moved fine, prob something
is machined off, gonna send it back.
Old Apr 21, 2019 | 10:52 AM
It held vacuum and still didnt open ? If you pushed the valve would it open or is it actually stuck solid ?
Old Apr 21, 2019 | 11:50 AM
forcd ind's Avatar
I had orig put it in a vice with a socket and it would open/close, I guess china bit
me in the *** on this one, lol.
Old Apr 21, 2019 | 12:58 PM
truckdoug's Avatar
I set mine really stiff like that. I only want it open when the combined force of high negative manifold pressure and positive charge pipe pressure can unseat the valve
Old Apr 21, 2019 | 01:07 PM
Depends on application which he still hasnt stated.
If blower, then it needs to open fast/easy.
If turbo...less of a concern, but if you want it to be functional then it still needs to be capable of opening.
Old Apr 21, 2019 | 01:34 PM
forcd ind's Avatar
Post 6 says turbo-but I got bigger problems, 4L80E I built seems to lock up
when I try and move the truck.
Old Apr 21, 2019 | 05:36 PM
truckdoug's Avatar
ah bummer. are you using the stock pcm with an 80e segment?
i'd say check out the automatic transmission forum on here, but they're meaner then we are lol
Old Apr 21, 2019 | 06:37 PM
forcd ind's Avatar
I wired it for man shift until I can afford a controller, but I disc. that which puts it
in limp mode, rev and 2nd. Still goes 1' for/back then locks up. Its got to come out,
I was only trying to get it in my other bay where the lift is, guess I need to call in some
muscle (pushers), lol. I'll just stick my old 400 in until I feel like tearing it down.
Old Apr 23, 2019 | 08:02 PM
truckdoug's Avatar
you can use a stock pcm as just a trans controller. there's a write up on the sloppy wiki. I did it behind an old school 454 and it worked really well
Old Apr 24, 2019 | 06:06 AM
forcd ind's Avatar
I saw that setup some time ago, wouldn't you need HP tuners to still adjust it.
Pulling the pan off the trans today, hoping maybe the 1st/rev band pin is holding
it, if not it has to come out. When I built it, it went together OK, was a little tight, but
I convinced myself it was OK, because I wanted this project running-my bad, lol.
Back on the valve, the spring that came with it was so strong it kind of jammed the
piston in the closed position, I found a weaker spring in my pile of parts (sometimes
its good I don't throw out stuff, lol) and with my hand vac it opens now-I will just have to
play with springs until I get the desired opening.
Old Apr 24, 2019 | 03:26 PM
truckdoug's Avatar
ah the ol self sabotage eh? no sir, i dont know anything about that lol
Old Apr 24, 2019 | 05:45 PM
forcd ind's Avatar
I seem to have a history of that, lol-about now glad nobody bought the old
turbo 400 switch/pitch, it will be in tomorrow.
Old Apr 25, 2019 | 02:56 PM
truckdoug's Avatar
huh i didnt know there was a 400 version of that. I had a "jetaway" 2 speed with the switch pitch converter and it worked rather well. of course being 19 i tossed it in the trash for an m21 set up lol
Old Apr 25, 2019 | 05:36 PM
forcd ind's Avatar
Yep, 64-65 Big Buicks used them, chevy guys would convert their 400's with the parts.
I built this one years ago, now just use it as a stand by if I temp need a 400. The converter
is a 13", now I am a little worried it might not clear the turbo cross over pipe-$hit just keeps
snow balling, lol. Beer time tonight, had enough of cars..
Old Apr 25, 2019 | 11:15 PM
truckdoug's Avatar
smart move. i usually stop after doing some aerodynamic testing of expensive parts lol
