Recent long crank times before start
What's the best place to start here to figer' this thang out? So far no problem, but I drive this thing often and far, would rather get it figured out first.
Doug, what exactly in the cranking fuel? Cranking VE table or something else??
I have also wondered if richening up the primary VE table in the idle area cells would help. It idles pretty lean, sometimes pegs the WB lean while idling long enough.....
look under Engine> Fuel >Cranking Fuel> FA (fuel adder) Multiplier stage 1 vs time and bump fuel like 5% all around as an experiment. it takes a while since you want a cold start for every test.
and the going lean at idle could be a couple things.
First I would verify your base running airflow (Engine>Idle>Airflow>base running airflow) actually mathes your idle air needs. alternate tuning this, and your IAC effective area to get your IAC step count to around 50 or so. You'll probably have to do a couple TPS re-learns (i'm sure you know how that works)
once you have a stable hot idle then you can really dial cold starts.
another benefit to having the IAC effective area dialed is that throttle transitions become way smooth since the IAC can soften the airflow with the Throttle Follower
And what is your definition of loooooooooong ?
Like 2 turns, 5, 10, 20 ? a time period ? other ?
Presumably no fault codes are present ?
Oh boy, hittin me with the data, numbers and whatnot lol. I get it though, it's the only way to really quantify something. Because otherwise it's totally subjective....
I'd roughly estimate that when it does this that it will crank for 5 seconds with nothing... Then I'll back off the starter and try again... Same deal.....
I should also mention.... When it's doing this, I will crank as mentioned in the line above and when I release the starter it will go totally (or nearly) quiet and THEN, the engine will fire off!!
I have only been able to drive it once since posting this but today I fired it up cold and I cycled the key a few times before attempting to start and it fired INSTANTLY... Kinda points to a fuel pump check valve or maybe a fuel pressure regulator??? (Stock LQ4 Reg)
Nah, no fault codes, other than the failed MAF of course since I'm 3 bar SD.
then try a start. Depending on what operating system, some you can adjust the fuel prime.
Since it was ok, I would look for something, maybe do a comp. tune, plugs, fuel filter, etc.
You could even have dirty injs., not allowing a good prime. Those things are hard to track down.
Maybe 2 seconds at worst, but rarely even that. So there is no way that is in any way a problem.
By all means check fuel pressure when cranking and starting.
Check for fuel being injected ( not too much, not too little )
Check for spark
And of course check there is air available.
if you don't have one you can rent a fuel pressure gauge from autozone and see what it's doing in each instance
key on (does pressure build and hold or bleed off)
then while cranking, running (whats fuel pressure vs manifold vacuum)
like you said, could be a regulator, pump check valve or maybe a leaky injector
you can pull the rail with the injectors still attached, prime the pump and see if any are leaking
Maybe not your issue but a easy enough one to fix
You're spot on about grounds. I learned the hard way from previous vehicular debauchery that you can never have too many grounds. I put pretty thick ground cables going between: block, body, frame.. A few of them are even redundant with extra grounds duplicating those three main areas.
Now let me ask you guys this... I stabbed a cam in this thing a ways back and subeone on this very forum was kind enough to help me get the idle airflow stuff dialed in after I installed the bigger cam.. I have always done all of my own tuning, thanks largely in part to all of the talent floating around on this board, among others.. RonSSNova, truckdoug, ddnspider, ChopperDoc, subeone, Lsxford, BCNUL8R... I'm probably forgetting some because it's kinda late and I'm a few beers in at this point, so apologies to anyone if I have forgotten! Anyways, subeone got me fixed up where it was much better than before.. However, the RPM sometimes will dive down, and rarely... the engine will kill out.... I'm not bitchin! Super grateful subeone et al! But, I wonder is there more improvement to be had there that could be causing this?
1) Car will start within 1 revolution (instantly) when *Cold*
2) In a taco bell drive though for example, when idling for a long time and waiting for people to give their orders, things get hot... After I finally give my order, I turn my car off so the people behind me can hear their order (my car is loud). But It takes a SCARY amount of cranking before it finally fires up. To the point where I feel "****, im stuck here in a drive through" and it'll finally start *whew*. I'm talking maybe... 1st hot crank continuous for about 20 revolutions. letting off. Then cranking again for 20 revolutions... letting off. Over and over, before it finally starts.
3) After a cold start, and once things warm up, when I come to a stop sign and go to neutral, my RPM's will drop to 500 and the engine will almost shut down.
So all 1, 2, and 3.... are exactly the same problems OP is having. DarthVader replied to my thread on this here: https://ls1tech.com/forums/pcm-diagn...dle-issue.html
Keep in mind, I haven't yet had a chance to try much of his suggestions (post 6 specifically) as I've been out of town. But he understands the issues pretty well, and has a good idea of what to change. Just wish I had time. (Thanks again Darth). Maybe those parameters will help you.
EDIT:
Lsx 427 swap - Speed Density - Open Loop - All sensors in working condition as far as I know - No fueling problems...again, as far as I can tell/know. However, My problem #2 tells me that all my cranking isn't actually helping it start, it's simply just needing to cool down enough to be able to start again. Perhaps the cranking however IS helping, by cooling down the rails (billet rails + aluminum intake manifold heat soak?) - and finally allowing it to start...
