Another 5.3 single build.
Old May 8, 2019 | 11:15 PM
Sebambam's Avatar
Default Another 5.3 single build.
Team/ experts
I need an advice
5.3 l33 stock bottom end with gapped rings
799 heads with 660 springs
Lunati turbo cam (.651 lift), matching lifters.
Sooo
Im looking to build a SINGLE 88 mm street/ strip
Setup. 4l80e trans
What 88mm turbo do you guys recommend
( mid price range)
What HOLLEY. Engine management system do you recommend
( enough for street and strip)
70 nova 4link chassis. 9 inch big tire setup
Old May 9, 2019 | 01:30 PM
68roadrunner's Avatar
sloppy mechanics 8's for 8k build. start following the youtube channel.
VS racing T6 turbo...call him for advice.
ECU - holley terminator X...done
Old May 9, 2019 | 02:15 PM
svslow's Avatar
Do you have a power or ET goal?
Old May 9, 2019 | 05:01 PM
Sebambam's Avatar
Goals are streetable 800
And crank up psi for 1000+ on track
Old May 9, 2019 | 05:24 PM
Sebambam's Avatar
Oh im following already
Old May 10, 2019 | 11:23 AM
RonSSNova's Avatar
Nice Nova
Mine is also L33, 799 heads etc.
Runs in the 8’s with a much smaller BW 76mm turbo. S476 with billet compressor wheel.
I’m no turbo expert, but 88mm sounds really big?
Ron
Old May 10, 2019 | 06:59 PM
Sebambam's Avatar
Nice Nova
Ron
I want a t6 flange turbo. And 80-88 gets me at least in the ballpark
Old May 10, 2019 | 07:00 PM
krazy4's Avatar
I'd just run a cast BorgWarner S480. It will make the power you're looking for and won't break the bank.
I would avoid the chinese clones, but people do have good luck with them.
Old May 10, 2019 | 07:14 PM
MY_2K_Z's Avatar
Billet t6 s475 would be a good choice
Old May 11, 2019 | 12:54 AM
Sebambam's Avatar
Thought about a s480
Whats a good source to buy from?
Old May 11, 2019 | 09:48 AM
RonSSNova's Avatar
The S476 is a T6
Check out Forced Inductions.
They have all the BW T6 models
Old May 11, 2019 | 10:05 PM
krazy4's Avatar
Search 177287 on ebay. Great turbo for the money.
Old May 12, 2019 | 03:20 PM
jayyyw's Avatar
Nice Nova
Ron
What kind of power do you make on that? I have a T4 S476 with a 96mm turbine and 1.10 from FI. Going on my manual C6 Z06 with a SBE 5.3
Old May 12, 2019 | 06:43 PM
krazy4's Avatar
You should be able to make an easy 800whp with that not even pushing it that hard.
Old May 13, 2019 | 02:58 PM
RonSSNova's Avatar
Even though I run a dyno, mine hasn’t been on it.
The Wallace calculator says 900+ to the wheels. Just shy of 157mph @ 3450lbs. And not very aero. 24psi E85
Old May 13, 2019 | 03:21 PM
jayyyw's Avatar
Thank you for the info. I'm under 3,000lbs in a C6 Z06. I was told I should be able to trap up near 170mph with it turned up. Not much of a track guy, so not sure that's possible or not. First venture into the turbo game.
Old May 13, 2019 | 08:08 PM
RonSSNova's Avatar
Very cool. Those cars are light.
I’ve also got a C5. It’s closer to 3300lbs. No turbo but will get a 6.2 this winter.
Are you stick shift then?
Ron
Old May 13, 2019 | 11:52 PM
Sebambam's Avatar
What you think is possible with this setup?
Old May 14, 2019 | 08:40 AM
jayyyw's Avatar
Ron
Yes, still stick.
Old May 22, 2019 | 10:37 AM
Project GatTagO's Avatar
The TerminatorX is capable, bit if you're going to do fancy boost control strategies and have a bunch of extra I/O, the Dominator would be a better option.
Andrew
