Ddnspider's- Project Wrong-Way- Rear Mount Turbo Thread
Old Jan 1, 2020 | 04:23 PM
  #461
ddnspider's Avatar
More detail.
So where is that filter ? What size are those hardlines ? Are you sure that factory tee fitting...is full bore throughout ? Filter is in the stock location, just prior to the factory tee block. Feed line is stock whatever size that is, 5/16?? Not sure if the factory tee is full bite throughout but I would guess so.
What is the makeup of that return ? Image doesnt show much...but I assume the hardline nylon is in some shape or form the return ? Is it full bore throughout ? With no restrictions ?
Stock is Hardline from the tee block to that nylon line to the factory bulkhead return line. All I did was remove the 2ft section of Hardline and replace with braided AN and added the FPR. As far as I know it doesn't get pinched down anywhere...but that should cause HIGH FP, not LOW FP.
The vac signal...from where exactly ? Is it a dedicated line ? Have you tested the FPR with a Mityvac to ensure the top chamber does not leak ? ( Many actually do a little....not an issue with say a 1/4" vac line direct from the intake. But as you're maybe a few feet away a small leak could reduce pressure quite a bit.
I have a vacuum block off the intake manifold post TB. There is 1 line that runs back to the WG and it's tee'd off of that. I've tried pinching the vacuum line with the car running with no change in FP. I have not done a mityvac on the vacuum port. I could pull the FPR and add a gauge to the 1/8NPT port, 2ouldnt be a big deal.
A gauge tee'd off directly at the vac/FPR would indicate any issues there too. But a test with a Mityvac is good, and you may need some sealant around the adjuster threads.
( Although a leak there under vac, you'd think FP may rise as opposed to fall )
I answered in red in the quote above.
Old Jan 2, 2020 | 08:31 PM
  #462
ddnspider's Avatar
https://www.supraforums.com/threads/...-30psi.604888/
Random Google searching and I found a guy on the Supra forum with almost the same issue and he went through all the same stuff I did with checking voltages and swapping pumps and regulators blablabla. Turned out to be a failing wideband sensor that drifts lean when warm and not setting base pressure with a warmed engine. Not positive thats my issue but it was an interesting read with many similarities.
Old Jan 3, 2020 | 02:40 AM
  #463
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Gotta watch them ricers. The sensors they use dont like beef very much. ;-)
Here is the new bulkhead stuff.
https://www.racetronix.biz/customkit...kc=bcwa-fl98hd
If youre trying to use a wideband to fix drivability issues youre putting too much trust in it.
Thats what narrow bands are for.
Running on stock regulator that would not matter also which you did for a little bit.
Old Jan 3, 2020 | 05:49 AM
  #464
stevieturbo's Avatar
Except fuel pressure dropping has nothing to do with the wideband. You could have 50 widebands fitted or none...still wont affect fuel pressure ( unless 50 draw too much current in the system I guess lol )
Old Jan 3, 2020 | 07:14 AM
  #465
ddnspider's Avatar
I don't have drivability issues. I could certainly turn on fuel trims and go closed look and allow the computer to correct for the drop in pressure (proved that with the above idle log pic), but that's just a bandaid.
Old Jan 3, 2020 | 07:15 AM
  #466
ddnspider's Avatar
I believe he also had a bad FP gauge in that thread. I am aware that the wideband and fuel system are not related 🙄 it was an interesting read. I still plan to beef up the power wire from the alternator.
Old Jan 3, 2020 | 08:24 AM
  #467
AwesomeAuto's Avatar
Can you increase pressure by adjusting the regulator once it starts to drop?
Can you wrap some rubber around the return line and slowly clamp it to increase pressure once it drops?
I doubt its your pump. In order to drop pressure at idle, it would have to be flowing about less than 10% of its rated output. It should be able to hold pressure at idle.
Grab a can of freeze-off from the parts store. Use it to cool down your fuel pressure sensor and regulator while its idling at low pressure.
Old Jan 3, 2020 | 08:38 AM
  #468
ddnspider's Avatar
good thoughts. I'll add those things to the list to try. Should have some 8AWG wire early next week to redo the power wire just in case.
Old Jan 3, 2020 | 09:16 AM
  #469
I just noticed how close your turbo is to your tank lol.
Your overheating the fuel. Hot fuel naturally cause pressure drop.
Gasoline vapor pressure is 5 PSI at 160 degrees and 15 PSI at 210 degrees.
If it goes over 210, things get bad.
Old Jan 3, 2020 | 09:39 AM
  #470
ddnspider's Avatar
That is actually where I started this whole investigation but several things have me ruling that out.
1. This will happen on a dead cold start within 10 min of idling where the turbo isn't generating any heat over what a muffler would.
2. I can put my hand on the heat shield above the turbine and it's warm but not hot.
3. I can go for a 45 min cruise on the highway and maintain fuel pressure, it only happens and idle/stop and go.
4. I reached under the car after a drive and the fuel pressure reg isnt hot, not even sure I would say it was warm, more like ambient.
Old Jan 3, 2020 | 10:13 AM
  #471
tblentrprz's Avatar
Have you confirmed actual pressure is dropping? Do you see injector pw or % increase when pressure drops? Where is your meter ground connected when measuring fuel pump voltage? Voltage drop on ground side has caused many to chase their tail. How difficult would it be to cap the return from press reg to read fp dead head/max pressure when problem is occurring?
Old Jan 3, 2020 | 10:21 AM
  #472
Freeze-out on the pressure sensor would rule out engine bay heat soak causing bad readings.
Those sensors are typically only able to compensate for temperature variations up to 170* F. Any higher and the readings start to fall.
They stop working complete somewhere before 250, a lot less if they are your typical $16 China ones.
Just don't freeze the sensor, it'll do the same thing at 0* F.
It almost sounds like a false reading more than anything, especially if you don't think the fuel temps are really getting over 160.
Old Jan 3, 2020 | 10:48 AM
  #473
ddnspider's Avatar
Using a transducer at the rails to log fuel pressure. Running OL at the moment so not sure I'd see IPW change. Meter ground is to the ground stud in the hatch that is tied to chassis. Only option I have for clamping the return is throwing a vice grip on the braided AN line.
Old Jan 3, 2020 | 10:50 AM
  #474
ddnspider's Avatar
You know, I actually stuck a large box fan under the hood at the sensor to try and rule out the sensor doing something flakey with temp, but freeze spray is a good idea and more pointed. It is a typical Amazon 100 psi transducer so who knows when the engine is sitting at 180 lol.
Old Jan 3, 2020 | 10:56 AM
  #475
Freeze spray on the regulator....is pretty dumb.
If the fuel lines are not hot, and the FPR is not hot...then quite obviously the fuel is not hot.
Old Jan 3, 2020 | 11:04 AM
  #476
I originally thought that his pressure sensor was in the regulator at the 1/8" port, which is why I recommended it.
Old Jan 3, 2020 | 11:05 AM
  #477
ddnspider's Avatar
At this point I'm willing to try just about anything....and I think he is more referring to freeze spray on the fuel pressure sensor.
Old Jan 3, 2020 | 11:07 AM
  #478
I have one measuring coolant pressure in the passenger side head. I've issues with belts jumping over 7K RPM and overheating the car immediately.
The pressure sensor readings would be ~20 PSI when the engine was at normal temp and would taper off to zero by the time I shut the car off.
Even at normal temps around 185, I can't trust the sensor readings, and only use it to measure quick spikes/dips for lifting heads or blow hoses.
Old Jan 3, 2020 | 11:22 AM
  #479
Cheap sensors can often give odd readings, especially if subject to nasty fluids or temperatures.
A good quality sensor not so.
But cooling system pressure with the sensor installed on the engine itself, due to water movement within the system as well as pressure fluctuations due to coolant temp....you will see swings of pressure in the system. That is expected, you just need to work out what is normal for your setup.
You will get more stable readings from a sensor installed in an air space in a header tank, although it may not be quite as responsive here to very minor head lifting.
It is a whole other topic in itself though
Old Jan 3, 2020 | 11:25 AM
  #480
ddnspider's Avatar
The only reason I don't think it's just a fuel pressure sensor issue is I can see the wideband trend lean as the fuel pressure drops.
