Ddnspider's- Project Wrong-Way- Rear Mount Turbo Thread
Old Jan 14, 2020 | 02:45 PM
  #561
ddnspider's Avatar
Originally Posted by TrendSetter
sounds like youre doing things the hard way. guess most of us are guilty of that.
I just follow the same method you do
... why fix what isnt broken? actually i usually fix things until they're broken.....
  #562
ddnspider's Avatar
it'd be interesting to log pressure at the compressor outlet, and at the intake, just to see how much is lost with a rear mount.
Im more curious about backpressure LOL
Old Jan 14, 2020 | 02:49 PM
  #563
ryeguy2006a's Avatar
Just read through the whole thing, nicely done!
Old Jan 14, 2020 | 03:02 PM
  #564
TrendSetter's Avatar
yeah my evo feels like ive just been stepping on a rake over and over and refuse to stop.
then i had a perfectly running really fast silverado and im about to saw the frame off at the control arms because weight.
Old Jan 14, 2020 | 03:18 PM
  #565
AwesomeAuto's Avatar
The couple of times I've measured backpressure on a rear mount setup, it was lower than a comparable front mount setup, for the same reason measuring EGTs at the rear gives you a lower reading.
The exhaust cools and condenses. Helps those guys running tiny turbines get away with it.
The import guys do some crazy stuff sometimes.
We did a test where water was being misted into the exhaust on a rear mount civic to test the differences in EGT and backpressure with/without the water.
EGTs dropped a great deal obviously, but backpressure only dropped slightly due to the expansion of the water turning to steam.
So the guys basically turned the exhaust into a giant heatsink, to try and let out as much heat as possible before the turbo.
I believe there was even an intercooler involved at one point.
Backpressure tanked. Big time. Power went up. I remember spool being hurt though but I don't remember how much.
Old Jan 14, 2020 | 04:13 PM
  #566
stevieturbo's Avatar
Interesting example, albeit front mount. RH is really putting them out these days !
Obviously a rear mount would be worse in every respect with losses/restrictions everywhere. But good to highlight what backpressure does on a bad setup.
Old Jan 14, 2020 | 04:53 PM
  #567
ddnspider's Avatar
Thanks man.
Old Jan 14, 2020 | 04:55 PM
  #568
ddnspider's Avatar
Water injection POST motor? That's pretty wild. You remember Zombies rear mount saga? I read over that a bunch when picking my hotside.
Old Jan 14, 2020 | 05:03 PM
  #569
ddnspider's Avatar
That video pretty much highlights why I'm wondering lol. 7665 turbo on a relatively large 5.7. But generally you go down 1 size on the turbine for a rear mount which is why Im hoping I'm in the sweet spot. Had several people concur with this turbo even though "it's the dumbest turbo ever for a front mount" lol.
Old Jan 14, 2020 | 08:57 PM
  #570
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Grabbed one of my 6.0 gen3 dished pressed pin piston/rods on accident but top down is .180. Thats quite a bit less than our ls1 style. Their ch on paper is 1.328-1.330. I get 1.335 when actually measured. Thats to the top of the piston. dish is .040 deep x 3.218 roughly. This should be in a separate thread. Ill compile info.
Old Jan 15, 2020 | 11:52 AM
  #571
It was just for a test. We welded a bung in the exhaust and tossed the biggest nozzle we had in it. There were backpressure and EGT sensors immediately before and after the turbo.
Those guys ended up spraying 100% meth through that nozzle at high boost at one point, I wish I was there for that. I heard there was a fire, broken parts, and a few quarts of oil on the ground.
Old Jan 15, 2020 | 12:18 PM
  #572
ddnspider's Avatar
ROFL...."hold my beer and watch this".
Old Jan 15, 2020 | 02:49 PM
  #573
ddnspider's Avatar
Just bought a meth kit lol. Time for more boost...
Old Jan 21, 2020 | 11:45 AM
  #574
ddnspider's Avatar
No pics atm, but a few updates:
Meth kit is on the way from another member on here. Bought an M10 nozzle and some additional 4" pipe to move the MAF upstream so I can still spray pre-TB but post MAF. Going to try and tune without it so its just there for cooling and added safety since I'll be using WWF not boost juice or anything.
Racetronix is sending me a replacement FPR due to some issues with the first one. They were quick to open a ticket and are sending out the new FPR with return shipping for the old one next day.
Also bumped my desired airflow at cold start a few g/sec and it got rid of my cold start surging finally. Cold start is rock solid now.
Picked up 1 of those upper dash pads to cover the factory broken one instead of the fabric overaly. People seem to say the new ones fit decent and look pretty good. Cleaning the car up a bit so it looks as good as it runs
Once I get rid of some of these stock wheels/DR's I need to figure out a set of drag tires to run when I want some sort of reasonable traction...
Old Jan 21, 2020 | 06:29 PM
  #575
ddnspider's Avatar
Now that's a little cleaner.
Old Jan 21, 2020 | 09:51 PM
  #576
truckdoug's Avatar
i want to make that cold pipe out of one peice for you
Old Jan 22, 2020 | 06:06 AM
  #577
ddnspider's Avatar
Lol, please do, just remember there's that pesky MAF in the middle
Old Jan 22, 2020 | 05:46 PM
  #578
you can buy the little aluminum piece that the maf bolts into. thats how i did my old ls2 s10 intake pipe.
order up some tube and bring the bits by sometime and we can make those silly couplers go away
Old Jan 22, 2020 | 06:20 PM
  #579
jayyyw's Avatar
ICT billet makes the MAF bung. (2) 90 degree pipes merged together, reduce all those couplers down to 2.
Amazon Amazon
Old Jan 22, 2020 | 08:13 PM
  #580
ddnspider's Avatar
I hadn't considered that, good idea!
