Can I get 480-500ish rwhp on 92 oct pump gas?
Mods are in sig.
I like the nitrous, but it is not really the best for the street where I spend 99% of the time.
So I am wondering if a procharger on lower boost would give me 480 or so rwhp that I am looking for w/o having to use e85 or meth.
My heads have been milled .030, so I have a little bit more then stock compression.
I am not looking to set the world on fire, but I would like around the same performance that I have on the bottle.
[Only run 100 shot pill's on the street]
I have done quite a bit of looking, but the guy's that I am seeing here are looking to lay down some serious power, so I am not finding the info that I am looking for.
So can 480 or so whp be done reliably with my engine set up w/o having to run e85 or meth?
Don't know why it's not showing up.
Stock 01 bottom end, PRC stage 1 heads milled .030, GM Hotcam, 1-7/8 headers, no cat's, slp lid, ls6 intake, powerbond underdrive pulley, nitrous outlet plate with 100 shot jet's for the street, 150 for the track, FLT level 4 trans with a Yank 3600 stall, 3.73 gears, 27" hoosier qtp's.
Mods are in sig.
it's a very modest goal, no reason why it should not be doable...although the extra CR maybe not such a great idea.
And stock 5.7 pistons are not renowned for their robustness, so will be on borrowed time regardless of the boost or the nitrous. Although a centri will be easier on things.
I only run 93 pump as I have no easy access to e85. With that being said I run 12-15lbs on the street with a Stock 5.3 with ported heads. I also run about 14* at 15psi with a small shot of wiper fluid to keep things happy right after the FMIC. Car only sees street miles but I drive on the street like it’s a track. Making about 650 at the crank so I’m over the 500whp mark on the cheapest 93 pump I can find.
You should be able to do it no prob. Might want a little wiper fluid to help any detonation etc.
I have been hearing that about the stock pistons for years now.
But for me at least, I have not had any issue.
Car has 107k on it now, and I am on prolly my 30th btl of nitrous.
I even had a plug melt down once when I forgot to change tune's and a bore scope showed the piston and cyl suffered no damage.
Of course, now that I have said that...
Stock 5.3 is like 9.5:1. I never measured anything out but I also went from paper head gaskets to MLS. Even if it was 10.5:1 u could still boost it no problem on 93. The key is timing and keeping IATs down. But like I said watermeth is a game changer, 50/50 mix (boost juice) on 93 pump is equal to something like 113 octane or something. Wiper fluid (-20 blue stuff) is like a 70/30 mix so that drops the octane a bit but the added water is better for detonation, plus I buy a bunch of
gallons when it’s on sale for like $1-2 a gallon which is cheaper than 5 gallons of 50/50 boost juice by a lot.
