Huron twink kit plug issue
Old Nov 20, 2019 | 01:32 PM
GT Griller's Avatar
Default Huron twink kit plug issue
What are you guys with the fbody twin kit from huron doing for plug wires? I keep burning #5...I've triple insulated but cant keep it from burning up. Manifolds are wrapped as well but that #5 wire just gently rests on the manifold...using MSD wires right now.
Old Nov 20, 2019 | 02:40 PM
Superman09's Avatar
LS1Tech Sponsor
Twin F-body Kit? F-body V3 manifolds have excellent plug wire clearance so I am shocked to hear of any plug wire burning. Please email me some more info and photos and I'll be happy to assist! Jon@HuronSpeed.com
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 20, 2019 | 04:51 PM
GT Griller's Avatar
will do and yes the fbody twin kit I wanna say mine is a v2 tho cause my cold side doesnt have the threaded iat sensor bung.
Old Nov 20, 2019 | 04:53 PM
Superman09's Avatar
LS1Tech Sponsor
Yeah, sounds like an older kit. New V3 kits all have excellent plug and wire clearance, OEM like. Shoot me that email and I will be happy to help out!
__________________
Old Nov 20, 2019 | 06:29 PM
LLLosingit's Avatar
You might want to edit the title lol...."Huron twink kit plug issue"
Old Nov 20, 2019 | 06:33 PM
Dragframe's Avatar
Definitey the wrong forum for twinks 😂
Old Nov 21, 2019 | 12:30 PM
ascastil's Avatar
Oh no, I didn't even notice the title. Hope that doesn't mean anything.....
Old Nov 21, 2019 | 12:42 PM
Superman09's Avatar
LS1Tech Sponsor
Customer has older V2 manifolds and is using some MSD wires. With those wires you can bend the ends to gain all the clearance you need and should fix his issue. Also a lot of thick heat wrap around each primary is stealing a lot of real estate on his set-up that isn't necessary (we do not recommend completely wrapping everything, only tight areas, due to wrap trapping in moisture and heat) Please see below the current plug wire clearance on the V3 manifolds as well as how the MSD wires can be used to create additional clearance
__________________
Old Nov 21, 2019 | 09:26 PM
GT Griller's Avatar
I swapped some new wires in and bent them out of the way we will see how they hold up. Thank you for being super responsive and willing to help!
Old Dec 1, 2019 | 06:33 PM
68roadrunner's Avatar
Great and honest vendor 👍🏻
