Rear end ratio for boost
dodge dart 3800lbs
ls 5.3 862 stock heads,
btr stage 2 turbo cam
edelbrock intake , 1250cc injectors
bw s480 turbo , 1.25ar. 2.5"cross over pipe, 3.5" dump
w2a intercooler, turbosmart boost tee.
coan powerglide trans , dana 60 rear 4.10 ratio. 3500converter
terminator x ecu
I realise its a big turbo for the motor, and the rear end is very short ratio. starts building boost at 4200-4500 rpm in first hits 6psi at 5500.
only a street car, I will turn the boost up higher once I am happy with the tune or get my e85 setup.
how much difference will 3.54 ratio make . this is expensive with these diffs, with the gears it will cost about $1000 .
i was planning on turning the boost upto around 20psi , seems like with first i wont have enough rpms
Your gears with late spool, I don’t think you’ll ever get traction lol. I’d go taller than the 3.5x
just don't want to get a Dyno tune done or e85 setup for higher boost until I have the gears correct
I just don't want to spend the coin if I don't have to obviously lol, I get a lot of people sayin put low gears and it will boost a lot quicker, but I also realise the turbo is way oversized for a stock 5.3 with a cam for street driving. so potenitially that late spooling turbo is the result.
Worst case, put it all together and if it’s a slug till very end then get another turbo. Either way the taller rear end if going to be needed.
Im 3200lbs and gears are a joke at 4.08
Edit, sorry I thought the converter said it was a 4500
Track car makes all that rhetoric irrelevant... select gear for the power and mph goals in the 1/8 or 1/4 or 1/2 mile that your planning on using the vehicle for
that 7-8 is measured on the intake manifold with an autometer vacuum/boost gauge.
how much of a turd around the street would it be with a 3.23 or 3.55 gear ?
ready to make a switchup
https://ls1tech.com/forums/forced-in...lly-click.html
So finally after getting a set of 3.55 motive installed
they were pretty loud whining.
got them done somewhere else , significant improvement but still a bit crap. ( could be bcoz of the extra muffler now more noticeable)
bigger problem
car seems much much slower , same eboost2 settings, only makes 6psi by 6300rpm , made more with the 4.1 gear and got there much quicker.
the muffler is a 14272735-78
although seems like wouldn't do much , it sure quietened the car a lot , so could be a big restriction
still needs a dyno tune , but off the terminator x and some street driving sure went good before .
( I will say though that because of the less revs , and less noise could be in my head but I don't really think so )
any advice thanks
