Rear end ratio for boost
Old Aug 27, 2020 | 03:25 PM
  #101
lscamaro234's Avatar
I cant check what the dwell times are like that as i just have it set for GM 24x , i can go to custom and adjust, but doesnt give any details on the current setup
Old Aug 28, 2020 | 07:39 AM
  #102
Forcefed86's Avatar
The crank signal has nothing to do with dwell time on the coils. I'm far from a Holley guru. But I'm told by those that are you can adjust and check dwell. Has to be done from a laptop. (can't do it on the baby screen) There is an advanced setting check box. Once this is checked you can go into ignition and look at the dwell times and adjust them if needed.
Old Aug 28, 2020 | 01:33 PM
  #103
Yeah that's how u would set a table to input whatever u like.
I'm just saying unless u go custom and setup the table mine is just clicked under a 24x motor and won't let u see what the actual dwell times are for that setting
Old Aug 29, 2020 | 07:28 AM
  #104
jimmyg's Avatar
Originally Posted by Z32_5.3
My buddy had a 5.3 with stage 2 cam 76/78 turbo making 500rwhp at 9-10psi. I think your numbers are low. This is on 93 too.
he is measuring in KW. 367kw =500 rwhp
Old Aug 31, 2020 | 08:33 AM
  #105
Forcefed86's Avatar
So set the advanced table to 4 ms across the board in boost and 3 ms at cruise. I'm pretty sure you can go much higher on dwell with the LS2. I don't believe they autofire like the D585's. you'd need to research that. But 4ms isn't going to auto-fire anything. Guys wiht eh square truck coils go as high as 7ms in boost, then pull it back to let the coil cool at cruise. AHving stable voltage is also key here. If your volts drop way down at RPM, the dwell tables may be altered quite a bit.
Old Sep 1, 2020 | 04:12 AM
  #106
found on the data logs i am running 1.5ms thorughout.
if i set it to say 3.5ms once in boost , thats what holley says to set this GM coil at. would it be worth opening the plugs back up to .025"
will that have much effect on the motor ?
Old Sep 1, 2020 | 06:35 PM
  #107
Bad Apache's Avatar
Up the dwell first and see how it runs. Then up the gap a few thousands at a time till you experience blow out or reach a happy spot. The widest gap you can run will give the best available spark to the mixture. It's a balancing act between gap and enough spark energy to jump the gap under cylinder conditions.
Old Sep 1, 2020 | 10:46 PM
  #108
Seems to run fine now with 1.5ms and. 015"gap
so is it worth trying 3.5ms and opening plugs to. 025"
or only if I add more boost and run into trouble
Old Sep 2, 2020 | 07:16 AM
  #109
ok ive made a mistake the data log i looked at was 1/100 and its the only one where i had the ignition set incorrectly and was on 1.5ms dwell.
im actually set at 4.5m/s .
the time i had 1.5m/s and the .015" gap it ran fine under boost.
the holley instructions say my ls2 coils shud have a maximum dwell of 3.5ms , so maybe ill set it a bit lower and see. possibly they r geting too hot and firing incorrectly ?
if so am i better off going with 1.5ms out of boost and anything in boost 3.5ms
Old Sep 2, 2020 | 10:31 AM
  #110
Forcefed86's Avatar
Never heard that on the LS2 coil. If you aren't at the higher dwell for any length of time I can't see the coils overheating.
The Holley does do individual spark and fuel right? Not batch fire? You can idle and cruise around at 1.5 and just run the 3.5 max setting in boost. That still seems low. I'd verify that. They may have put it in there just to cover their asses on the D585 coil. Since they tend to auto spark much above 4.5ms. I'm not aware of the LS2 coil doing that (but I'm not positive) Also the MS usually varies a lot with voltage. So if voltage drops the ms usually jumps up to counter. I'd need to see the tables and how/what Holley does with dwell.I don't allow mine to fluctuate with voltage. Cruise at 2ms and bump it up to 5 on my square truck coils. .025 gaps and no issue at 19lbs on e85. Similar in my rx7... tho I run d585s in that and limit max dwell to 4ms in boost.
If it runs fine gapped at .015 you may just leave it instead of trying to reinvent the wheel. Tiny bit of power may be lost and idle quality usually suffers a tiny bit at small gaps. Thats it!
