Exhaust manifold bolts
Old Feb 2, 2020 | 12:39 PM
fastlt1's Avatar
Default Exhaust manifold bolts
What is the general consensus now? Just torque them down dry, anti seize, or blue loctite
Old Feb 2, 2020 | 12:41 PM
truckdoug's Avatar
new, grade 10.9 with 13mm heads, dry, in sequence starting in the center and alternate working to ends of the head
Old Feb 3, 2020 | 07:25 AM
mightyquickz28's Avatar
Like Truckdoug said... Plus, After I drive the car around and it's had a chance to completely cool down, I go back and retighten all of them since it seems that when the engine heats up, it squishes the gaskets a little bit and after cooling down , there may be a miniscule gap between the block, gasket and header flange. If the bolts are in anyway loose at that point, the vibrations can start them backing out, which allows gas pressure to escape, which can compromise the gasket sealing quality. My take on it anyway.
Old Feb 3, 2020 | 08:34 AM
LS1-IROC's Avatar
Studs are the way to go.
Old Feb 3, 2020 | 08:41 AM
AwesomeAuto's Avatar
Studs are cheap, definitely the way to go, especially for turbo setups.
Don't loctite your bolts in.
Old Feb 4, 2020 | 08:34 AM
RonSSNova's Avatar
I just use stock bolts with the 13mm head and GM multi layer gaskets. No antisieze or anything.
0 issues.
Old Feb 5, 2020 | 08:29 AM
transam69230's Avatar
ARP studs FTW!
Old Feb 5, 2020 | 11:46 AM
jayyyw's Avatar
I switched to studs and will never go back.
Old Feb 5, 2020 | 04:25 PM
minytrker's Avatar
New stock bolts, a dab of antisieze and torqued what we do.
Old Feb 5, 2020 | 04:39 PM
RonSSNova's Avatar
I can’t get my drivers side manifold off if I have studs. Tried it. So maybe FTW for some......
Old Feb 5, 2020 | 06:52 PM
01CamaroSSTx's Avatar
Okay how did the stud get into the head?
Old Feb 5, 2020 | 06:56 PM
I know... Kinda defeats the purpose of having a stud in the first place!
Old Feb 6, 2020 | 08:17 AM
minytrker's Avatar
Thats the issue we ran into trying studs, had more combos they didnt work than worked in. When they work they are great for sure but unfortunately we couldnt use them very often.
Old Feb 6, 2020 | 08:49 AM
I can't get mine on unless I have studs. Turbo manifolds and headers don't share the same fitment qualities lol.
