boost creep
Old Feb 19, 2020 | 05:43 PM
drhill's Avatar
Default boost creep
Hi everyone,
I'm having some issues with boost creep on a 5.3 L33 with a 76mm precision turbo. I'm having trouble controlling boost with a 38mm Tial wastegate. The gate is on the bend of the crossover from non-turbo side of the motor, so it's only venting exhaust from one side of the motor. I do see a lot of people putting their WG's in this spot successfully. It's dumping to atmosphere through a short straight tube. With a 8.7 lb spring I'm at 11 lbs in 1st gear, 12 lbs in 2nd gear and creeping to almost 14lbs in 3rd on a 1/4 mile run. I can definitely hear the gate opening. I;m not currently using any boost control, just running spring pressure.
Any suggestions on a best course of action? I'm honestly just looking for 15 psi steady across the board. Is it as simple as just a larger WG? Or do I have to re position it? I know 15 lbs should be easier to control than 8.7 lbs but it seems I'm not even close right now. I did try a 11.6 lb spring setup in the WG previously and had similar creep up top.
Old Feb 19, 2020 | 06:57 PM
drhill's Avatar
i guess my other question would be - considering my current boost, could I just put in a stiffer set of springs in the WG to get to 15lbs consistently since it's only creeping to just under 14 lbs now? I don't fully understand if WG's open progressively or more like an on/off switch? It seems to me like it's either open or closed but I may be wrong....
Old Feb 19, 2020 | 08:01 PM
customblackbird's Avatar
Single 38mm is a bit on the small side for a 5.3 if your trying to run lower boost numbers. You should be running dual 38mm or a single 44mm at minimum. Stepping up to a 50 or 60mm wouldn’t be needed but would be worth it on bigger setups. I bet adding another 38mm to the other side would help. Or block off the 38 and run a 44mm where the 2sides join before the turbo. I have a 5.3 with a billet 78/75 and I can run 6psi no problem with a 60mm HKS clone which has a smaller 2” outlet even tho the inlet is 60mm.
Old Feb 20, 2020 | 07:02 AM
GMCGreg's Avatar
Sounds like a good traction control strategy the way it is now - lol
I think if you raise the spring pressure you're going to just raise all those numbers -over 15 lbs in 3rd
I second the relocation of current gate or add a second one
I have a single 44mm vs gate on a 6L with no problem controlling boost down to 5 psi (haven't tried lower)
Old Feb 20, 2020 | 07:38 AM
ddnspider's Avatar
This.
Old Feb 20, 2020 | 09:17 AM
Black_Sunshine_99's Avatar
This.
While I do agree with both these guys lol, ideally you'd add another 38mm wastegate to the other bank and add an electronic boost controller.
I ran gate spring pressure for years thinking an EBC couldn't improve performance much....I was very wrong.
Old Feb 20, 2020 | 09:32 AM
AwesomeAuto's Avatar
Originally Posted by drhill
Hi everyone,
Sounds like you bought any one of 10 different turbo kits that put the gate in the crossover instead of in that passenger side turbo manifold.
You'll always have trouble controlling boost there. You can upgrade to a larger gate, but it won't be as simple as clamping it on.
A larger fitting will need welded onto the piping if you want it to actually make any difference.
Old Feb 21, 2020 | 04:42 AM
Dian's Avatar
whats wrong with "boost creep"?
Old Feb 21, 2020 | 06:10 AM
ddnspider's Avatar
Running more boost than your tuned for isn't smart.
Old Feb 21, 2020 | 04:26 PM
stevieturbo's Avatar
So just tune it for that boost.
But to resolve the problem, most sensible and easy would be another 38mm gate in a suitable location.
Old Feb 21, 2020 | 04:40 PM
ddnspider's Avatar
Please tune your car to 100 psi, make it creep to that number, and report back. Not everyone has the fuel system, etc. to tune for higher boost levels. Simply tuning for all higher boost is a bandaid, not a solution if you want to run less boost.
Old Feb 21, 2020 | 05:33 PM
his creep of 14psi, isnt quite 100psi though.
Old Feb 21, 2020 | 05:36 PM
ddnspider's Avatar
It's not? I thought 14 and 100 were next to each other.
Old Feb 25, 2020 | 01:17 PM
Dian's Avatar
i think turbo guys get too much obsessed with boost creep for some reason. for centri guys its how it works. there sure is a benefit of having less boost at toque peak than at redline and usually you dont get full boost with a well mached turbo much before torque peak anyway, so you dont loose anything there.
the same for the gears. one of the benefit of turbos is less boost in lower gears.
Old Feb 25, 2020 | 01:20 PM
ddnspider's Avatar
Why would you compare boost creep to a centrifugal blower? They're not remotely the same thing.
Old Feb 25, 2020 | 03:01 PM
Yeah that isn't how it works at all.
For a Centri-blower, you size the pulley around how much boost you want, and boost increases to that point with almost zero possibility of excess boost. Its expected and controlled.
With turbo boost creep, you size the spring around how much boost you want, and then you end up with excess boost that you had no way of expecting and zero way of controlling.
Its uncontrolled boost. No amount of money spent on a boost controller will prevent or control it, the root cause itself must be fixed.
And not getting peak boost before torque peak with a well matched turbo? You've never driven a well-matched turbo V8 combo I take it? My Nova made 20 PSI at 3600 RPM.
Old Feb 25, 2020 | 04:47 PM
Exactly as Awesome says. Boost creep IS uncontrolled boost and is not wanted ( it can be worked around if it is small as said earlier, but it is still uncontrolled boost )
And you would never have peak torque at a lower boost....higher boost will almost always yield more torque...that's the whole point of boost !
And there is nothing set in stone to say you will have less boost in lower gears vs higher gears. With good boost control on a well matched setup, you can have whatever boost you want in any gear.
Old Feb 25, 2020 | 04:48 PM
islander033's Avatar
7 Second Club
I’ve run a single 50mm wg on a 88mm turbo with no creep.
ps. You can run a wg on a centri setup and control boost too...
Old Feb 25, 2020 | 10:15 PM
Dian's Avatar
why would boost creep be "ucontrolled" boost? because your controller doesnt control it? its as inherently build into the system as on a centri. i have driven my turbo car for many years with intentional boost creep i got by limiting wastegate valve travel.
and if you got full boost at 3600 your choking the engine at 7000 for sure. (unless we were talking an electronically contolled variable turbo as on the late model cars where you get flat torque from 2000 on.)
op, if you get 11 psi in first and "creep" up to 14 psi in third, i consider that an ideal situation. think about it. (i had my car set up with about 5 psi of "creep".)
Old Feb 26, 2020 | 06:15 AM
ddnspider's Avatar
Ok KingTalon.....
