Turbo Headers or Stock Manifolds
The difference between 760HP and 800HP with a T76/75 on the street is going to be tough to feel most of the time unless you freeway roll. The occasional run at the track will be noticeable but you will have plenty of fun with either while you chop away at your 60' times with a home built street car.
Turbos, fuel and tuning make up for the minor imperfections caused by differences between manifolds and heads combinations.
And a fun fact I was told... The "Ohio boys" made 2300hp on stock truck manifolds....
no seriously, it’s amazing how much power can be made with low flowing stuff in between the engine and turbo. It’s after the turbo that makes more difference. For the most part.
in my experience, if it seals, it'll make more power than you know what to do with
Stock Manifold Pros: Spark Plug Access, Low Cost/readily available, Longevity, superior heat retention
Cons: Weigh considerably more than iron, limited configurations, don't look cool.
Headers Pros: Look cool, optimized flow/velocity by design, lots of configurations, light weight, accommodates exhaust gas sensors
Cons: Cost, crack over time, can impede spark plug access, radiate heat unwrapped, wrapped still don't retain heat as well as iron
I'm sure there are some things I'm missing but these came to mind.
