LSA Supercharger install on a C5 Corvette and what it takes to make it fit.
#161
Good news. The new 408 short block has been shipped and should be here late this week or early next week. Pictures to follow. I have almost everything to put this poor car back together so hopefully it will go together reasonably quick.
The following users liked this post:
The BallSS (07-11-2022)
wannafbody (07-23-2022)
#163
It has arrived and I think she's beautiful.
Thanks to AMS Racing for getting this out ahead of schedule.
The BallSS (07-19-2022)
Mr. Black (07-19-2022)
#166
Whoa! Looks great, you turned the old one into a coffee table yet!?
#167
So what brand pistons did they use?
#168
The following 2 users liked this post by Mr. Black:
theunderlord (07-21-2022), truckdoug (07-29-2022)
#169
Almost got it ready to install back into the car. Fell short of getting the balancer installed due to a technical difficulty of a severe variety lol. Will have to call Innovators West on Monday morning.
It's probably a blessing as it supposed to be 95 degrees plus most of next week.
Had fun getting the stock windage tray and pickup tube setup configured with the 4 inch stroke crank. It's easier than some make it out to be. Turned out well.
#172
That just looks muscular. But maybe put some Crime Scene Tape around the pieces-parts under the car. Seeing that would give me PTSD.
Curious....
I assume that the OP Sender is just a place holder at this point? And.. Is there a reason you stayed with the BatWing Pan? I know that some have swapped it for a different one. Why do you have a non vented valley cover - on a boosted engine - vs the one with a tube? I have SOOO much to learn.
In central PA is is also 'Hotter than the Hinges of Hell' as well - tomorrow is to be a record breaker - 96, Heat Index well over 103! That's F'n HOT!
I'm gonna start chasing a Vac leak on my project. - still can't get it to fire. I have a BIG HF fan in my garage - to blow HOT air on me while I sweat.
I feel ya.
Curious....
I feel ya.
#173
Curious....
I feel ya.
Curious....
I feel ya.
That oil pressure sensor is original to the car and it works and it doesn't leak. I can just about guarantee that a new one even in an AC Delco box is made in China.
Many have switched to the LS2 pan from C6 but many of the many that did report back of oil starvation problems when launching the car. The batwing pan does a pretty good job at controlling the oil. and it was free to help get the car back up and running quicker and most importantly help with the budget. This project like so many has gone way over budget and I don't make a lot of money anymore so every little bit helps.
Funny I actually removed my CTS-V PCV valley cover in favor of the old school dumb as a brick valley cover on purpose. I am running the race version of the Mighty Mouse catch can breather setups and with that version you do not do anything with the valley cover and it gets capped off. No reason to put that fancy valley cover back on the car just to cap it off.
Jimbo1367 (08-18-2022), JumboShrimp (07-24-2022)
#174
#175
Currently running an 8.5" crank pulley and 2.45" blower pulley.
#176
For those of you that are bored off your ***. Check this garbage out.
#177
No I don't think so. If anything the pulleys will remain the same and if the boost decreases a bit I'm ok with that. Boost may remain close though as I took out a cam with like 5 degrees of overlap and am now going to be running a cam with -2 degrees over overlap.
Mr. Black (07-29-2022)
#178
Thanks for the info ryeguy. I am now going to be running the Summit Ghost cam as well. Also I was off on the balancer size. the 10% Innovators West is 8 1/8th diameter with a 2.45 upper.
Shortblock is ready to go back in the car tomorrow morning.
99 Black Bird T/A (10-15-2022)
#179
Sitting here waiting on my UPS guy for some shorter pushrods.
This thing is probably only a couple hours away from running.
It looks so purdy almost whole again.
So much nicer of an installation without the adapter plates under the blower.
Super weird to see what the rotors in the blower look like new with all their coating on them.
