Spark Plug Question
Old May 12, 2020 | 01:27 PM
Shownomercy's Avatar
Man-Crush Warning
Default Spark Plug Question
Swapped plugs out after a couple hundred miles on the new hotside/ECU and to me, the plugs seem to be too cold for the engine.
I had TR6 plugs in it prior, but switched to the BR7EF, gapped at .025
Thoughts?
Old May 12, 2020 | 05:31 PM
forcd ind's Avatar
Rich tune? I dont see a lot of diff bet. my 6's and 7's.
Old May 12, 2020 | 05:35 PM
ddnspider's Avatar
Pic is useless. Need up close of the ground strap, need pics of the porcelain, pics of the threads showing heat.
Old May 12, 2020 | 09:05 PM
tblentrprz's Avatar
Fueling needs work and maybe a little timing. Pump gas? Was car re-tuned with new ECU? What is the target AFR at idle and cruise? Have you run a WOT pull with a new plug to see what's going on?
Old May 13, 2020 | 06:50 AM
Man-Crush Warning
14.0 afr commanded at idle.
If I was asking about WOT stuff, this is just asking about the sooty/carbon on plugs from a few hundred miles of daily driving.
Pump 93, target afr is 14.00 at idle and cruises at 14.5, WOT is 11.5 but have not done a WOT pull
Old May 13, 2020 | 06:54 AM
ddnspider's Avatar
Ah, my fault. Seemed kind of obvious its way rich at idle/cruise so I thought you were asking about WOT.
Old May 13, 2020 | 07:47 AM
forcd ind's Avatar
Curious how the TR6's looked in comparison, they make an extended tip BR7EFS. You might be able to lean it out some, more in the idle, low speed area.
Old May 13, 2020 | 08:34 AM
SE-R Spec's Avatar
How big is your cam and what timing are you running at idle? MAP Kpa?
Old May 13, 2020 | 08:43 AM
Man-Crush Warning
227/227 114, 25* at idle, 47kpa
Old May 13, 2020 | 08:48 AM
ddnspider's Avatar
plugs shouldn't look like that with negative overlap. Have you put the wideband in both banks to confirm they agree? Why are you setting idle at 14.0?
Old May 13, 2020 | 08:51 AM
Man-Crush Warning
No provisions for widebands in each bank, single wideband for the holley in downpipe. But, that was a worry of mine, until all the plugs came out the same.
I could bump idle AFR a little, just started tuning it with remote tuner and I expressed I wanted it to be a conservative tune.
Old May 13, 2020 | 08:59 AM
ddnspider's Avatar
Set it to idle at 15:1. Check the plugs again in a couple hundred miles.
Old May 13, 2020 | 10:36 AM
tblentrprz's Avatar
I would show plugs to tuner. Is he targeting peak vacuum by adjusting fuel and timing at idle and cruise?
Old May 13, 2020 | 11:39 AM
squarles67's Avatar
Agree with others you need to lean out the idle and cruise a bit.
Don't know what boost you plan to run but a 3177 plug is a non-projected plug - NGK-BR6EF
Old May 13, 2020 | 11:47 AM
Man-Crush Warning
Not sure on what exactly the tuner was looking for, car drives great so far. I will ask about the idle vac/timing/afr
Hoping to max out my turbo so 15-20psi
Old May 14, 2020 | 09:43 AM
mightyquickz28's Avatar
Drag racing spark reading guide
Old May 14, 2020 | 02:46 PM
Forcefed86's Avatar
Pump gas?
Not much to read on a plug that's been in the engine a couple hundred miles. If your cruise and idle are as lean as you can go and the AFR checks out at 11.3 to 12.5 during a WOT pull, its fine. If your putting in a new set do a quick pull and shut the engine down.... then pull the plugs to get a good read them. Even a few minutes at idle or cruise can muddy up a good plug reading. May add a simple inexpensive washer fluid injection kit. It will clean the CC/plugs quite a bit and has other benefits.
Old May 14, 2020 | 05:59 PM
Man-Crush Warning
Yea regular 93 stuff.
I have the parts to spray water/meth but never bothered to use em so took it all off the car.
Old May 14, 2020 | 06:27 PM
ddnspider's Avatar
Pump gas?
bull honkey.
