spool time s480
Old Oct 22, 2020 | 01:01 PM
Black_Sunshine_99's Avatar
Originally Posted by lscamaro234
Open scroll, would be hard to make a divided setup now.
Tune could help for sure, but it's expensive here for a good one. So I want to have the right setup when I go
The open scroll is undoubtedly hurting spool since the twin scroll splits the flow up hitting the inside and outside edges of the turbine wheel.
I'd focus on the tune since changing the hotside isn't an option.
Old Oct 22, 2020 | 01:09 PM
ddnspider's Avatar
Id go with a smaller turbo for the goals. $300 gets you a turbo that will act like big block torque.
Old Oct 22, 2020 | 01:10 PM
3 window's Avatar
How are you controlling the gate(s)? Relying on compressor pressure? Onboard air? CO2?
Old Oct 22, 2020 | 03:00 PM
lscamaro234's Avatar
relying on compressor pressure for boost control ,
its hard to know what to expect from spooling up, from my data log u can see it barely makes any boost til 5000rpm. and this is not a 3 speed so that isnt very quick.
Old Oct 22, 2020 | 03:30 PM
Could it be the combination of the glide and 3.5 gear so it doesn't have the power to pull from down low and therefore spooling the turbo slow.
It built boost quicker in time With my 4.1 rear. But had more rpm
Old Oct 22, 2020 | 06:10 PM
3 window's Avatar
The glide isn’t causing the issue. It’s more than likely the fact that you’re waiting for the compressor to make pressure to operate the gate (if you’re putting pressure ON the dome). If you had an onboard air system or CO2 to pin the gate it’d make boost no sweat. The tune could be at fault as well but it’s not the trans. If you think it is, send it to me and I’ll keep us as a spare.
Old Oct 22, 2020 | 06:31 PM
haha , okay well good you think its not the trans.
ive had a 22psi spring in it to keep it closed tight and still no change
does that boost ramp look close and a tune get it a little better , or is something way off
its very hard to say without going in a similar car or something to compare to , especially when some people are sayung boost is instant or comes in real quick
Old Oct 22, 2020 | 07:03 PM
jordoza's Avatar
Something is very wrong. Ive seen s480 t6 spool on a 5.3 by 3500rpm. If it won't make boost below 5000rpm then you most likely have a leak somewhere either hotside or coldside. No way is that normal. I guess it could be tune related but it would have to be way off to make that turbo spool that slow in my opinion. Have you tested the hotside with a smoke machine. You can do the same thing with the cold side. Its crazy how much a small leak can cause a huge loss of boost.
Old Oct 25, 2020 | 07:43 PM
I am going to redo my hot side crossover as it doesn't sit how I like. One time I check it's sealed the next time I run air through and it has a small leak.
my converter flashes to 3600 so I can't see it making any positive pressure before that.
at 5000 I have about 6 or7psi.
it's a btrs2 cam.
226*231 113+4
could this be too much cam causing it to come in to late on a street car
Old Oct 26, 2020 | 01:14 PM
M33P's Avatar
it's a btrs2 cam.
226*231 113+4
We make ~12 psi by 6k on in a 6.0 with btr stage 2 cam and a t4 s480 so I dont think the cam is an issue.
Old Oct 26, 2020 | 01:22 PM
ddnspider's Avatar
That is slow as crap....I've never used an S480, but it seems like either that turbo is WAY oversized or the tune/combo is way off.
Old Oct 26, 2020 | 01:43 PM
  #32
By 6k I would be at full boost.
Old Oct 26, 2020 | 02:03 PM
  #33
Forcefed86's Avatar
Thats the T4 S480 right? What intake? Somethings off IMO. My 4.8 StG2 summit cam made boost more quickly. Thats with the 1.32 T6. Are you talking about just stabbing it from a dead stop? Or on a trans brake?
May take a few steps back and test the basics. Cranking compression? Sync timing, etc...
Old Oct 26, 2020 | 02:47 PM
  #34
I am talking stabbing from a stop or slow cruise.
I think I might have a some leaking on the hot side going on.
I'm getting manifolds crossover fixed next few days probably just get the dump pipe modified to suit my s369. Maybe more suited to what I'm after anyway.
Old Oct 27, 2020 | 07:48 AM
  #35
Forcefed86's Avatar
I'm sure that will be a night/day difference, but something is still wrong. Slapping a baby turbo on may make it better, but it shouldn't be as bad as it is now. I'd try to find whats wrong first personally.
If you don't find any big leaks on the hot or cold side, and its still slow to spool once leaned out... it has to be something mechanical I'd think. I Do agree though. Should be in the 12's w/ more aggressive timing until the turbo is lit. No reason to be down in the 10's on E with an intercooled setup at baby boost.
I swapped in a gen4 5.3 one year and power was down a ton, super sluggish to spool etc. Finally found the crank keyway was 8-9* retarded. (factory crank!) Cranking compression was horrible, down in the 140's. Degreed cam and cranking compression jumped up to 200! (JFR trip 12 cam) After that, the engine was literally snappy, just like your looking for. Would light the tires before boost came in. Picked up 12mph at the track at the same boost level. It was a mean little 5.3 combo. Trapped 159 at 24lbs with a S476. (untouched 799 heads).
Old Oct 27, 2020 | 11:21 AM
  #36
SLOW SEDAN's Avatar
That's not over sized at all, a GTX 94mm spools faster on a 5.3L than what he's seeing with his S480, something is amiss.
Old Oct 27, 2020 | 11:50 AM
  #37
ddnspider's Avatar
Thought so lol.
Old Oct 27, 2020 | 05:38 PM
  #38
I'll do a ComPressing test See what numbers it's getting.
I get the feeling the hot side leak is the problem, I think it's gotten worse since I first done a test on it.
is the 369 still gonna be a decent choice for a street car if I went with that one
Old Oct 27, 2020 | 06:45 PM
  #39
SLOW SEDAN's Avatar
Check any flex sections closely, I use copper RTV on all vbands/turbo flanges as well. If you get it all sealed up it should work much better. If your goal is truly 700hp an S369 may get you close but peak power is gonna be RPM limited and backpressure may limit timing as well. I ran twin S369's and they spooled faster then what you show for the single 80 so your problem isn't turbo size alone.
Old Oct 27, 2020 | 06:48 PM
  #40
ddnspider's Avatar
Something around 800engine HP. Shifting 6500
Based on this goal rpm should be ok with the S369.
