Track car fuel
Old Nov 15, 2020 | 11:46 AM
Z32_5.3's Avatar
Default Track car fuel
I’m putting together a track only car. Prob will do some Mexico dig runs too. Cars not a daily or street car. Already have a 700hp Tt 5.3 for that.
So I’ve been thinking because it’s only a track car. I don’t need pump fuel or to buy a meth kit to run my M1 with ($950) or IC etc.
6.0 , s480-485, have th400 rmvb built with brake and UCC converter already. 3000-3300 lb car (maybe less once stripped) 275/60/15 tire I can fit.
so what ideas for fuel should I use? I was think straight M1 because i can get local for $3-4 gallon. It’s prob the success behind holding my gen3 5.3 I have now. No need for intercooler. Car will just have a fuel cell in it.
Old Nov 15, 2020 | 05:07 PM
Bad Apache's Avatar
Track only, no I/C= M1. Fuel consumption is very high. So if your planning mexico trips, put in a large fuel cell. Build your fuel system for it and enjoy. It's pretty incredible stuff. Use caution though, very flammable and hard to see burning in daylight.
Old Nov 15, 2020 | 09:11 PM
AwesomeAuto's Avatar
M1 fuel consumption is over twice that of gasoline. Pretty hard to use on the street typically.
Old Nov 16, 2020 | 02:43 PM
Z32_5.3's Avatar
I wouldn’t drive this car anywhere really. Would be towed to a run or track.
Old Nov 16, 2020 | 02:44 PM
Z32_5.3's Avatar
Do I need special fuel lines or large injectors like e85? I need injectors I know but e85 is way higher.
Old Nov 16, 2020 | 04:12 PM
blackdak318's Avatar
Yes, you will need special fuel line and VERY large injectors. If you think you need larger stuff for E85, Methanol blows that out of the water. Targer AFR can be in the 3's! For a track only car it is definitely the way to go though. I would just go straight into a mechanical fuel pump and two sets of injectors as well.
Old Nov 16, 2020 | 04:20 PM
Forcefed86's Avatar
M1 is great, but is a pain. Yes, you need a ridiculous pump (usually mechanical) and BIG injectors. You' likely need 16 injectors. Check out what 500lb injectors cost and that $900 meth kit is chump change! lol. Methanol is corrosive and hard on things in general. Milks down oil if you go very rich with it, which you would need to do with out an IC. It attracts water... Basically not a user friendly fuel in any way. But it does work well!
What is the power goal? Do you have E85 close? E98 or barrel ethanol blends are another good option.
Straight c16 is great as well. But you won't get the charge and cylinder cooling you would with ethanol. So not as good if you don't want an IC.
Honestly you' prob get a decent ECU if its a drag car. So progressive methanol injection is cheap. E85 or E98 with meth inj would be my pick.
Or run a nice A2W IC with C16.
Old Nov 16, 2020 | 05:40 PM
Z32_5.3's Avatar
Just did a ton of reading. The whole M1 idea may be out the window. No need for it when pricing is so much lol !
Power goal is 950 wheel through the th400 with the 6.0 motor. Car will have a stand alone 100%. I have no issue with running a FMIC. Just thought doing pure M1 was awesome and easy to guarantee the power.
Because car is being towed around basically, doesn’t matter what fuel as long as I can buy a barrel of it.
Old Nov 16, 2020 | 07:46 PM
Bad Apache's Avatar
As stated, special lines, pumps, fittings, injectors and lotsa maintenance. But nothing smells better, lol
Currently working with my first methanol fueled car. It's N/A and mechanical injection and still a bunch of work. Very different to tune too. Wide tuning window compared to gas. I think you could pull off a relatively inexpensive methanol fuel system. Blow-thru would be the cheapest and for a race car, work just fine (look up Billy the Kid and their S10). You could get a used mechanical pump (dirt track guys), front mount cell, short lines and spend the money on injectors to do an EFI system.
Old Nov 16, 2020 | 10:29 PM
Forcefed86's Avatar
For 950 wheel I wouldn't bother with anything but E85. C85 or Ignite 112 are good E85 barrel blends. But you could likely drive to a pump somewhere and pump your own for very little $. Many have gone beyond 950whp with no IC on E85.
Honestly for a track only car, intercoolers are the way to go. The A2W stuff is just so hard to beat... But the Ice thing is a hassle.
I like the Idea of twins better for a track car. More economical too. You cam the crap out of them and make a few extra ponies NA, if you size them to keep back pressure at 1:1. You'll make quite a bit more power per pound anyway.
A healthy cam 5.3 with and A2W and twin VSR 78/75s just put down 1000whp at only 20lbs. Something to think about anyway. The VSR Cast 78/75 is like $400. The S366 clones are $380 would prob be a better fit for 950. . The Ebay billet knock off 78/75s are $270 each shipped. And you can get the .68 T4's with them for the same cost.
Old Nov 17, 2020 | 08:16 AM
For 950 wheel stick with pump E85, a decent intercooler of your choosing, and a run of the mill S485 or 88 will get you there easily.
Old Nov 17, 2020 | 09:09 AM
Forcefed86's Avatar
When we are talking the "cheap" S480+ sizes... Have we actually seen a VSR S485-S488 make more power than the standard VSR S480? I haven't. (not saying they don't either). And we all know the Forced Inductions units larger than the S480 really perform well. But they are Big money when compared to mid frame twins, and will always have more back pressure. Guess that was my point. Not that a single won't work fine.
Old Nov 17, 2020 | 11:21 AM
SLOW SEDAN's Avatar
For 950 wheel I wouldn't bother with anything but E85. C85 or Ignite 112 are good E85 blends. But you could likely drive to a pump somewhere and pump your own for very little $. Many have gone beyond 950whp with no IC on E85.
Agree on E85! He said he was starting with a 6.0, on mine the way the 78/75's spool with the .96 vband housing I wouldn't want anything smaller. It'll take a few less lbs of boost to hit 1000 on a 6.0 (esp one with good heads and higher compression) so could be looking at ~15PSI which really may not even need an intercooler if he can tune it safely and get the turbos fed fresh air and not behind the rad. On 10lbs without an IC my IAT's are lower than most LSA cars run daily but as the boost rises you need to pull some timing for the IAT.
Old Nov 17, 2020 | 03:18 PM
Agree with this for sure. If starting from scratch I would do twin 76-80's on mine rather than a large single. The VSR 85-88's make more with the new larger turbine offerings they have but with the standard 96 I would tend to agree with your assessment of the larger compressor wheels not really doing much. I saw Bewley say that the standard borg 96mm turbine only has the capacity to max out a billet 80mm compressor wheel. Anything larger than that isn't really getting you a whole lot.
Old Nov 17, 2020 | 03:20 PM
I did 900 wheel on 93+windshield washer fluid in a small cam 5.3 and a 4L80e at 26 PSI.
I couldn't fathom the idea of a bigger engine and M1 just to make another 50 HP.
Old Nov 17, 2020 | 03:45 PM
Dragframe's Avatar
If your not aiming for 1500+.. I don’t know why we are talking about methanol 😂
Old Nov 18, 2020 | 08:42 AM
SLOW SEDAN's Avatar
Bewley says a lot of ****, he also said E85 sucks and the 417 intercooler works
Old Nov 18, 2020 | 10:30 AM
He also told me my cam would never make power in my setup (it made 30 HP per PSI on a 4.8), that he tested the SS2 cam on Tooley's spintron and it sucked (this got him fired for lying), and that VSRacing turbos will never make power or go fast. He also literally calls himself a cam grinder (he has never cut a cam), and somehow thinks that choosing lobes out of Comp's lobe catalog means the cam his somehow is own proprietary design.
Bewley is a keyboard warrior that uses other's results as his "proof", having done very very very little on his own. Take everything he says with a grain of salt.
Old Nov 18, 2020 | 11:31 AM
Forcefed86's Avatar
He was pretty rude to me as well. But he has still spec'd the cams for some of the fastest cars out there. Record setting SBE cars etc. To say he doesn't know what he is doing is also not true IMO. He is defiantly a "my way or the highway" type though. Pretty close minded. Still... Can't argue that his "spec'd" cams work well in MANY setups. I'll give that to him.
Old Nov 18, 2020 | 12:40 PM
SLOW SEDAN's Avatar
I thought Brian spec'd the cams, John just sold them from the donut stand.
