Am I on track for 145-150mph?
Old Dec 19, 2020 | 09:38 PM
Sail Hatan's Avatar
Default Am I on track for 145-150mph?
Still Planning, I'm in on the huron GP. Went with a v3 t6 kit. I'm looking at running a SBE ls2 for now, until i can plan out a motor (or it lets go). Im going to get my fuel system together, radiator stood up, battery in trunk, and kit in and running at as low power as I can until I have the motor sorted. if its all in and running I can at least move the car around, plus ill be able to recoup money by selling injectors and exhaust and all that stuff.
Car has been 10.9 @ 129 @ roughly 500whp with the current set up, with a t56 that I'm planning on keeping. Currently a sbe ls1, btr4, tfs 220 heads (62cc), and a fast 102. Any chance I can reuse the heads on an ls2, with a thicker gasket?? maybe even the intake, at least for a bit?
what cam would you guys suggest?
what gears? car has 4.10s which I'm sure are useless.
I want to run an s480. Will this turbo be my best bet? was thinking about a VS next gen billet 80, since I can get one cheap. Maybe even if it's temporary until it's time to turn it up.
I'd love to make 800whp with room to grow.
Old Dec 19, 2020 | 09:47 PM
AwesomeAuto's Avatar
Do you have access to E85? I'd run your current combo with an S480 with E85 before I changed anything at all.
Old Dec 20, 2020 | 03:54 AM
Kingc8r's Avatar
I can't see any reason why you couldn't use those heads even though I'd love to buy them. I'd definitely go with less gear a buddy of mine has a huron kit and is M6 with 4.10s and he hates his gearing.
Old Dec 20, 2020 | 08:04 AM
Sail Hatan's Avatar
yes e85 is plentiful.
Old Dec 20, 2020 | 08:05 AM
Sail Hatan's Avatar
I figured 3.50 would be ideal.
Old Dec 20, 2020 | 12:45 PM
Run what you plan to then (the SBE LS2). Compression is a touch high for pump gas depending on what CC those heads are (largest puts them at stock LS2 compression).
The cam is a little big for a turbo setup but if you're running decent compression ratio, you can make it work, especially with those heads.
I'd just run it. The 1.32 A/R 96mm wheel will almost be a requirement for that combo to work good, but it'll work.
It'll definitely make a ton of power.
Old Dec 21, 2020 | 08:39 AM
Sail Hatan's Avatar
the cam I’m not reusing. I’ll take whatever the best suggested cam is and run that. For now, I’ll get it running, but I don’t plan on it being a killer with the max effort n/a motor set up.
I also really want to run a holley mid or high intake, am I going to be seriously hurting power over an ls6? I like the fact that I can run stuff under the holley if need be.
Old Dec 21, 2020 | 02:56 PM
Kfxguy's Avatar
just curious, what does this car weigh?
Old Dec 21, 2020 | 05:22 PM
I guess I'm the only one that favors using N/A cams in turbo setup lol
Old Dec 21, 2020 | 05:31 PM
ddnspider's Avatar
Run the intake based on intended rpm range. How the intake will act NA is how it will act in boost.
Old Dec 24, 2020 | 10:06 PM
Sail Hatan's Avatar
ok. I’d love to use a holley mid, but im
guessing it makes peak power way higher than my set up will. I’ll keep the fast until I source an ls6 or something...
Old Dec 24, 2020 | 10:57 PM
No, the Holley mid rise intake it terrible. TERRIBLE.
Literally nobody should use it for a performance option.
Old Dec 25, 2020 | 05:55 PM
Dragframe's Avatar
Read this a lot. Everyone suggests the short or high.. and says the mid is a pile. Was there some back to back testing that showed this was a terribly designed intake?
Old Dec 25, 2020 | 06:32 PM
Nette Spankins's Avatar
Default Zzzzz
Yawn 🥱
Old Jan 11, 2021 | 07:56 PM
Sail Hatan's Avatar
if it works I'm down!
Ive ordered a forced inductions billet s480. battery is in the trunk, have the entire fuel system. chrs1313 pump, 210 boschs, etc. have the radiator, fans, and hoses.
i need a boost controller/solenoid, waste gates, and blow off valves. also whatever
vacuum stuff.
I think my best bet is to get it running with the turbo set up and go from there, without changing anything on the motor. I can always plan for a motor after the kit is on.
