PWM Fan/Fuel Pump Question
Looking to PWM my fuel pump (4301) so I don't have it cycling 100% at idle etc, but want to prove system out on cooling fans first cause losing a fan is not the end of the world. Is the below image I stole from the internet a valid approach? I have 40amp SSR DD and will be driving em via Holley -pwm
Seems too easy to be right, so has me worried.
There’s better options for fans though. Oem modules from many gm and Ford vehicles work great.
I’ve used this one many times at 120hz
https://www.ebay.com/itm/Cooling-Fan....m46890.l49292
If weather cooperates tmmr, I will drive it and see how they do.
It is that easy, and the Crydom DC relay should be able to do 300Hz no problem at all. I run mine at 200Hz.
I tested at various frequencies and duties, and that just seemed to offer a little more flow than others.
I've a pair of 450's going, and intend to run a 3rd when needed. Currently on a 60A Crydom, but have a 100A if needed
it's already been covered very well in other threads.
This video explains it well.
And a means of suppressing the back EMF IS essential unless all the components in the system have been designed to operate without it, which most SSR's are not.
Basically compare it to what happens in your ignition coil.
12v in....you switch it off and what happens in the windings ? The field collapse causes that build up of energy to release and because of the windings, it is a very very high voltage.
Any inductive load is basically the same, except when you PWM it, you're doing it hundreds, thousands of times per second.
Still plenty for almost all methanol pumps except the most powerful, and even thing current will very much depend on how hard you're trying to work the pump.
ie. I believe this is for some ecu's or setups that behave strange, so that when you power off, both input terminals will be at the same potential...i.e off.
I have tried mine with the Syvecs with and without the resistor without issue, although I left the resistor in place. Because why not ?
This is Haltech's drawing which is pretty clear, with the 12v side PWM'd ( obviously add fuses/protection where needed )
