Guess Turbo HP for fun!!
Old Jul 19, 2004 | 11:40 AM
427's Avatar
427
Default Guess Turbo HP for fun!!
Built a 402 ci iron block forged shortblock for a customer with a single 94mm turbo.
Give me your best guess at HP and torque on engine dyno. We will run it later this week.
TEA Z06 cylinder heads.
8.2-1 compression ratio
Cam Motion solid roller
Jesel lifters, rockers and belt drive
Wheel to Wheel sheetmetal manifold with 105mm throttle body
Daily pan and dry sump pump
Wheel to Wheel main girdle with steel main caps
Wheel to Wheel Distributor drive
FAST controller
Kurt
Old Jul 19, 2004 | 11:46 AM
NA$TY-TA's Avatar
1050 RWHP and 970RWTQ
How much boost Kurt?
Kyle
Old Jul 19, 2004 | 11:50 AM
Excal's Avatar
on a engine dyno, i'm going for 1190hp and 1200TQ.
Old Jul 19, 2004 | 11:58 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Need a boost pressure to get a #.
Jose
Old Jul 19, 2004 | 12:00 PM
427's Avatar
427
Kyle, its on a engine dyno. We are just giving the engine a shakedown before we ship it so boost will be between 19-24 psi. Just need to test the head gaskets!!
Kurt
Kyle
Old Jul 19, 2004 | 12:49 PM
S_J_H's Avatar
at 19 psi- 1000 hp and 1200 TQ.
at 24psi- 1150 hp and 1380 TQ.
Old Jul 19, 2004 | 01:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
1560hp, 1186ft is my guess.
Old Jul 19, 2004 | 01:24 PM
Guido's Avatar
1320hp
Old Jul 19, 2004 | 01:32 PM
BLKWS6's Avatar
1420hp
Old Jul 19, 2004 | 01:44 PM
distortion_69's Avatar
1276.4 horsies.
1180 tq
Old Jul 19, 2004 | 02:22 PM
XLR8NSS's Avatar
Adkoonerstrator
What type of rpms will you be turning? 19psi-24psi at 2000 or 8000rpm
Old Jul 19, 2004 | 02:50 PM
LSs1Power's Avatar
19psi 1200HP on an engine dyno.
24psi 1400HP on an engine dyno.
Old Jul 19, 2004 | 03:10 PM
Koncrete's Avatar
^^^I am with him
Old Jul 19, 2004 | 03:21 PM
427's Avatar
427
I am going to say the sweeps will be from 3500-7000 RPM.
Kurt
Old Jul 19, 2004 | 03:26 PM
hellbents10's Avatar
LS1Tech Sponsor
I will say 980hp on 19 psi somewhere around 6800-7000rpm.
Old Jul 19, 2004 | 03:37 PM
Evil F1 SS's Avatar
Lots and lots of HP
Frame twisting TQ
Old Jul 19, 2004 | 03:43 PM
Z8'S's Avatar
Not Enough! :d
Reckless's Avatar
Super Moderator
1220hp & 1140tq @ 23psi
Old Jul 19, 2004 | 03:44 PM
InconFormula's Avatar
That thing should make an easy 1300fwhp and 1200ftlbs. Our little 382 with a T88/98 made 1150fwhp and 1006ftlbs. on 24 psi with a stock ls6 intake,stock ported throttle body,and hydralic cam. Kurt I know you'll be spinning that thing 8k because your crazy like that . Why a fast crapper when you have the bs3 there? And one more thing what the hell car is this thing going into? I'm getting a little nervous here. Still trying to work out a few bugs before the big 8 sec run. I'm sure mike will be in touch soon if not already. If this package does'nt exceed my estimate i will be very surprised especially with kurt having control of the dyno throttle and boost controller!! Steve.
Old Jul 19, 2004 | 04:13 PM
427's Avatar
427
Steve,
Customer requested FAST system. They won't let me go on the throttle or we would see 8000!!! They say there going to lock the boost control away from me too.
This thing will never race in this country so you should be safe!!
Keep up the guessing guys, this is getting good!!
Kurt
