Too much back pressure?
Old May 20, 2021 | 11:54 AM
  #81
Fallguy's Avatar
I had a well known tuner tell me that he had tuned a 5.3 with the exact same turbos. At 7psi the back pressure was 1.6:1.
when he swapped to the .82 ar it went to 1.2:1 and picked up 40whp
Old May 20, 2021 | 12:28 PM
  #82
Fallguy's Avatar
This is my .63AR GT35 T3 next the ".83AR" 72/68"
hard to say but I think my housings are smaller. They are really thin on top
fyi love the videos. If you guys ever come by Kelowna let me know.
Old May 20, 2021 | 12:49 PM
  #83
SLOW SEDAN's Avatar
Much the same, I saw a 5.3L go from a 88/96 to a 102/112 turbine wheel with a 100+hp gain, backpressure is a bitch!
Old May 20, 2021 | 12:50 PM
  #84
Forcefed86's Avatar
If you have an aftermarket ECU a 0-100psi transducer is $16 on Amazon. Def worth the $. Either way, as seen guys are making silly power... regardless of back pressure readings.
Also fwiw here are the numbers at lower boost levels.
727/882 @ 22
624/796 @ 20
630/737 @ 17
573/674 @ 14
  #85
Fallguy's Avatar
what Power and psi was that at?
Old May 20, 2021 | 02:09 PM
  #86
SLOW SEDAN's Avatar
727/882 @ 22
624/796 @ 20
630/737 @ 17
573/674 @ 14
Sub 20hp gains per lb isn't great. Better off skipping the baby $200 turbos and getting a single $400 turbo at that point, make 100-150hp more than those units on a good bit less boost.
Old May 20, 2021 | 02:16 PM
  #87
SLOW SEDAN's Avatar
Roughly 1025whp@20PSI.
Old May 20, 2021 | 02:21 PM
  #88
Forcefed86's Avatar
I agree, lots of better options. Depending on goals though, those are a pretty great value. I was thinking more along the lines of comparing power at boost levels similar to what the OP ran.
At that time, those cast baby GT3582's were $109 shipped! Pretty great value for turbos capable of 500+ crank each. The T4 versions do better on power, but the response isn't there.
I always wanted to do 3 of them just to be different. Cheapest set ive seen these days is $129 shipped.
Old May 20, 2021 | 02:33 PM
  #89
Fallguy's Avatar
here I am rocking 1200$ Precision’s 😕
While I was swapping the housings I went to rebuild them. Apparently these steel thrust bearings aren’t the best idea. So it’s an upgrade to go copper.
Old May 20, 2021 | 03:14 PM
  #90
Forcefed86's Avatar
That was kind of my point, those little bad boys should be putting out some power! Should be MUCH more efficient than the baby GT3582 china clones. I'd check your cranking compression. Ensure plugs are gapped way down at .015 or less and see if makes a difference. Something seems "off". I don't think it's a bad thing you went larger on the housings. Hope it solves your issues. Just bacuase china says .063 T3 def doesn't mean it specs out to that. While I'd assume precisions are accurate in sizing.
Old May 20, 2021 | 03:22 PM
  #91
Fallguy's Avatar
I hope it’s just the housings lol. But it could be something else. I’m running BR7ES factory gap at .024
Old May 26, 2021 | 08:07 PM
  #92
Fallguy's Avatar
Don’t know how accurate the tester was but 175psi on all 8 cly
also installed the new housings.
Old May 27, 2021 | 11:46 AM
  #93
SLOW SEDAN's Avatar
Looks good, looking forward to new numbers!
Old Jun 1, 2021 | 08:49 PM
  #94
Fallguy's Avatar
Went back to the dyno. 13psi made 477 with the old housings. This time 535whp
and at 16-17psi it made 594whp
Not too sure if the pump fuel has much more in it for me.
Old Jun 1, 2021 | 09:08 PM
  #95
Deude_Mann's Avatar
Very impressive gains! That is fantastic. That is one really impressive car.
You know, looking at the torque rise in your dyno plot with the old turbine housing, it looks like you gave up very little on spool response. After driving it around off the dyno, how does it feel on transient response compared to the old housing?
Old Jun 1, 2021 | 09:28 PM
  #96
Fallguy's Avatar
it did drop some. The car has 3.15 gears in it so it’s noticeable. But with the higher boost it hits harder now. I’m working on getting a Ford IRS 8.8 in the rear.
Old Jun 1, 2021 | 09:48 PM
  #97
Deude_Mann's Avatar
FWIW - I have a Ford 8.8 in my LS1 Miata. It uses a Ford Explorer aluminum IRS housing, and an Allison Truetrac differential, with a 3.55 R&P. The Truetrac is a very worthy differential for street or track. People even drag race with them. I am very happy with mine.
The limited slip Getrags are another good option. A friend of mine has one in his dedicated road race LS Miata, and does well with it on the track.
Old Jun 1, 2021 | 10:20 PM
  #98
Fallguy's Avatar
im on the fence on helical or clutch style. I hear if you break a helical style it can lock up bad. Don’t know how true that is.
Old Jun 2, 2021 | 09:09 AM
  #99
Z32_5.3's Avatar
Why does boost / tq seem so laggy? Not hating on you or car!
I had a tune that looked like this before and turned out the timing was super low on the bottom end going up to like 4psi. Got it retuned by someone else and he said need low end timing to get turbos going. Car is 600+ tq by 4000rpm now. Night and day. Same setup but diff tuners.
Old Jun 2, 2021 | 09:11 AM
  #100
Fallguy's Avatar
could be the way I have my boost control setup, I think we added timing down low and it didn’t pick up much.
I’ll take a look.
