Too much back pressure?
Old May 5, 2021 | 07:39 PM
Fallguy's Avatar
Default Too much back pressure?
Hit the dyno.... numbers not that great.
I’m thinking the small turbine housings (.64 ar) is just too small.
Here is the the setup
L33 5.3 (aluminum block)
Wiseco flat top pistons
K1 rods
LS2 intake
1000cc FIC injectors
walbro 525
Haltech 2500
BTR stage 1 TT cam/spring/ti retainer
Summit SFI balancer
LS9 head gaskets
ARP head studs
6262 billet turbos .63 vband housings
38mm v band gates
RXT twin plate clutch
T56 magnum
dual 3" i to single 4" exhaust with vibrant muffler
Made 477whp at 13psi with 14deg of timing and 535whp at 15psi with 14deg as well. We felt the car wasn’t making the power it should so we stopped. Was expecting around 600ish at 13psi.
Want to check back pressure and probably swap to the 1.05 stainless v band housing.
Old May 5, 2021 | 08:43 PM
Woodylyf767's Avatar
250 to 270 wheel NA is what that would be about. You picked up 58 with 2lbs and no timing. Sounds like you're getting in the turbo sweet spot.
I'm not a tuner or an expert but this seems normal to me. If you want 600 hp why not simply turn it up a notch? I'd guess those turbos would max between 650 and 800 rear wheel
Old May 5, 2021 | 09:08 PM
Fallguy's Avatar
you could be right. The first 3 plugs is when we were at 477whp. And the last two is when we added some timing to the 15psi. So adding the two psi only added a bit. Then we tried for more with the timing.
figured the back pressure was getting high and called it a day.
looking at others with twin 6262’s they sell making a lot more power. They seem to make 700-800 at 17 psi. And I have also seen them make 1050 at 24psi
Old May 6, 2021 | 08:40 AM
SLOW SEDAN's Avatar
Those numbers seem awfully low through a manual. What fuel are you on and who made the turbos?
Old May 6, 2021 | 09:49 AM
3 window's Avatar
Monitor backpressure so you’re not guessing.
Old May 6, 2021 | 10:05 AM
So you had 2 different timings at 15 psi? Was the original 15 psi @ 14 deg for 535 a typo? What did it do with other timing?
Fuel type ? I'm guessing not E with that timing
Old May 6, 2021 | 10:21 AM
ddnspider's Avatar
If 1 bar is double NA, your motor was ~260whp. What fuel and compression? Feels a little light NA. Post a dyno graph.
Old May 6, 2021 | 10:50 AM
Fallguy's Avatar
they are precision 6262’s and that was with chevron 94
Old May 6, 2021 | 10:52 AM
Fallguy's Avatar
it made 525 with 13deg and only picked up 10hp to 535 with 14deg
Old May 6, 2021 | 11:15 AM
Fallguy's Avatar
that’s what I was thinking should be 300-340 NA with a manual. I’ll see if I can get the graph from the shop.
Talked with another tuner. He has tuned a 5.3 with the same turbos. He said with the .64 at at 7psi the back pressure was 1.6:1
then they swapped the .84 housings made 40hp more at the same 7psi and the ratio went down to 1.2:1
Old May 6, 2021 | 11:20 AM
ddnspider's Avatar
When you say Chevron 94, is this that stuff in Canada? I've been hearing alot about how thats not really non-E 94 and people have been having issues with logs and such with that gas.
Old May 6, 2021 | 11:34 AM
Fallguy's Avatar
yeah we have it up in Canada. It’s non e 94. I hear it’s pretty good. But I’m not too sure. Could try shell 93. Apparently we are getting e85 this year.
something happened with Mohawk 94. They had to stop selling it. I think because it was getting thar rating because of the ethanol
Old May 6, 2021 | 12:13 PM
SLOW SEDAN's Avatar
Not sure why people would want non E fuel, more E the better! I agree .64 is a darn small housing, the larger ones would let it breath better. I run dual vband .96's on mine, runs better than when I had smaller .86 flanged units on there. What's your HP goal?
Old May 6, 2021 | 12:15 PM
Fallguy's Avatar
I don’t mind running e but our two main options here are chevron 94 and shell 93. Some debate over what is better.
As for goals I was thinking 600-650 on pump and 800ish on e85
Old May 6, 2021 | 12:34 PM
ddnspider's Avatar
Ive seen recently on 2 other forums people posting that theyre using that Chevron 94 and their logs looked lousy. I would try the Shell, but it also would be interesting to hear if the tuner said he was running into knock issues.
Old May 6, 2021 | 12:57 PM
SLOW SEDAN's Avatar
Should be easily achievable! Once you get E85 you'll never look back, for 800'ish you can always do E50 for a nice balance of cooling, MPG, and timing.
Old May 6, 2021 | 12:58 PM
Fallguy's Avatar
seems like the e85 we will be getting is always e60ish
ill also try the 93
Old May 6, 2021 | 01:29 PM
SLOW SEDAN's Avatar
ill also try the 93
Even better, can just run the E60 with no mixing.
Old May 6, 2021 | 08:42 PM
Bad Apache's Avatar
Ok I'll say it. Badass car! Always loved that style and thought an LS would be the best thing that could happen to any german car.
Old May 6, 2021 | 08:45 PM
Fallguy's Avatar
hahah thanks. It’s not much bigger than a Miata so even with that horsepower level it feels pretty sketchy.
