Intercooler question
Old Jun 13, 2021 | 10:14 PM
AARONLS1PROCHARGED's Avatar
Default Intercooler question
I started off my boost journey with a procharger D1SC kit with the twin intercoolers. And my boost gauge would read 15 ish lbs of boost.
when I upgraded to a front mount my gauge went from 15 to 8.
my friend told me that the gauge would go down because I had more room air with the bigger tubing an intercooler.
but I have another friend telling me that the front mount has restricted my airflow now that boost gauge has went down.
So what I need to know is do I need to put a bigger intercooler in it. The current one is 24x12x3.
Chang the pulley out to make more boost?
Old Jun 16, 2021 | 03:47 PM
ICRAZY6's Avatar
What engine? Compression ration? Pulley configuration?
Old Jun 16, 2021 | 04:30 PM
forcd ind's Avatar
Is that the core size, double ck for a boost leak.
Old Jun 16, 2021 | 10:31 PM
Stock displacement Ls1, just honed the block and put forged internals,
the pulley configuration is stock except with the procharger
Old Jun 16, 2021 | 10:33 PM
Yes that’s the core size
Old Jun 21, 2021 | 12:18 PM
ICRAZY6's Avatar
I would say that you have less restriction with the larger intercooler as you boost decreased. I have a 390 cubic inch motor and my D1sc is pushing 14-15psi through a front mount but I'm nearly maxing out the procharger with the 7.65" crank pulley and a 3.55" blower pulley.
Old Jun 21, 2021 | 12:32 PM
LilJayV10's Avatar
boost is just a measurement of restriction.
There's a good chance you are making the same power, if not more, at a lower boost level. That's a pretty significant drop in boost though.
You can go from a stock cam to an aftermarket cam and drop boost, you can put on better cylinder heads on it and drop boost.
Old Jun 21, 2021 | 12:45 PM
3 window's Avatar
Is there a rag on the intercooler? If not, send it back! Yes, boost is a measurement of restriction, to lose 7 psi is ridiculous. Monitor pre intercooler pressure and see what’s up.
