How are you testing for Turbo Back Pressure?
What's an affordable way to test your turbo back pressure? Are their decent kits on the market? Analog, digital? What are you using?
From my understanding you want a 1:1 ratio, At what point do you have to start worrying about too much back pressure? 2:1?
Could I use my Narrow Band O2 bung as a port to do some quick tests from?
Thanks!
Thanks!
It’s nice to measure back pressure and log it. as it gets toward 2:1, you can open the waste gate to relieve the pressure and keep everything in its “happy place”.
As for street car, I’d think just something like upthread with a peak/hold pressure gauge on the dyno (or for a street pull for that matter) to get an idea if your setup is as efficient as it should be.
Good luck
My 7875 on my LS1 started running out of breath around 6,500 rpm so an LS2 will just get there quicker.
If you can get a reading on the cheap then go for it, otherwise I wouldn't worry about it, you'll see power plateau when it becomes a problem.
or a bit fancier with a kit like this: Earls PK0001ERL Earls Exhaust Back Pressure Plumbing Kit (holley.com)
Could I integrate the output signal into my HP Tuners Pro interface?
What the heck is Dome Pressure?
I have the Huron Speed T4 AC Kit. For Turbo, I have the Turbonetics 7575 Billet with a 1.15AR housing.
Yess!!
