Exhaust flex coupler for turbo build
Even the bellows posted above backpressure has made them expand and those are a good bit stiffer than the braided joints but at least with overlapping pipes inside they don't typically blow out or send pieces into the turbo. So now I prefer solid mounting if I can, haven't had any issues with that.Been on the car since 2013.
my turbo is solid mounted to the frame. So I needed to use them.
They aren’t set up in any sort of radial twist.
This post got me curious. I have the hot side off for engine removal, so I poked the bore scope in there to look.
Still perfect.
Happy to see that
https://en.wikipedia.org/wiki/Marman_clamp
