Exhaust flex coupler for turbo build
I've been on Summit's website and have seen several Vibrant's that say not to use with turbos but haven't found any that will.
Thanks for any help.
I am wanting to put it about a foot down stream of the turbo. In the y pipe. I don't like how ridge the exhaust is not and honestly it's a PITA for remove/install it after some heat cycles.
I would like just a little bit of flex. The engine isn't going to move that much due to the BMR low mount turbo k member which is basically solid mounts with some small poly bushings.
With the coupler SS provided, when it fails, it cracks and you'll hear it and lose boost maybe.
When the braided ones fail, not sure if that includes the Vibrant ones, they look fine on the outside but will literally close up on the inside choking the engine.
I've seen them on a 2 1/4" pipe shrink down to less than a 1" opening but again, not sure if the Vibrant ones are the same.
It happens over time too, so the engine will start performing less and less until you realize there's a problem or something gets damaged or fails.
Are you talking pre-turbo or post turbo?
I've only seen them fail pre-turbo, never heard of one post turbo.
The HS V2 T6 kit mounts the turbo to the engine, none of the hot side is mounted to the chassis anywhere so I'm thinking a piece of pipe is the way to go.
The entire kit mounts to the engine so there is no need really to accommodate flex in the system from movement, maybe thermal expansion but again HS removed it.
It would be the same amount of work to do a piece of pipe or a slip fit, just don't want to have to mess with it again which ever way I go.
Those pipes are long too when compared to the HS T6 kit which makes my concern about the need for thermal expansion seem unnecessary.
Also look at the Holley turbo manifolds, lots of guys are using those cast manifolds with a solid crossover without issue. I had a kit like that for awhile that use a stock drivers side manifold and solid crossover worked fine.
