IAT what is considered to hot?
Your results may vary.
Seems more and more people are ditching the intercooler, on most setups its an often overpriced and overly heavy contraption to have on the vehicle if you aren't looking for every extra millisecond. On a typical street car I don't miss it at all, does a 1000hp street car really need another 50hp anyways?
sensors are slow spray and cool as best you can and hope your giving the motor the best chance to survive especially with varying degrees of fuel quality these days.
Boats are odd since they are usually wide open for long periods of time. Because of that, superchargers aren't the best choice IMO. LIttle $150 Gt45 turbo would put out the same power with ALOT more adjustability. I'd have a WG control setup like a throttle. That way you could be at high rpm cruising high speeds with little to no boost. Then add/pull boost when needed for acceleration.
Its like a proper fuel table vs relying on a big closed loop correction, being ahead of the sensor works better.
