Boost for the Masses - Engine Build
Old Apr 1, 2022 | 02:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Boost for the Masses - Engine Build
Currently my '67 is running a LM7 SBE, stock L99 heads, a Capizzi cam grind, ARP hardware and a Melling oil pump. My long term plan has been to build a forged LC9 and to run aftermarket heads.
I've been working with the following industry players for an all-forged boost engine that is getting built this year:Here is the list of parts that will be used. I'm still updating and adding to the list, so it's not complete yet:
GM LC9 engine block, bored .005 over
TFS-30619991 TFS 220 Cylinder Heads
SUM-180LS362224x Pro LS 3.622 crank
SUM-LS6125927 Pro LS 6.125 H-Beam rods with ARP 2000’s
SUM-2999273785-7 Pistons
ARP-234-4317 Head studs
ARP-234-5608 Main Studs
AAF-ALL87024 Cylinder head dowels
NAL-12575329 Chevy Performance O.E. 5.3L bore replacement head gaskets
TFS-21407500 pushrods
SUM-HTLSKIT2 Delphi LS7 lifter and tray kit
NAL-12561513 Long Crank Key
SUM-161000 Short Crank Key
CLE-SH2125S Cam Bearings
MEL-10295 Melling Oil pump
SUM-G1585 LS Engine Hardware Kit / Plugs Dumbbell/ Side Bolts
SUM-G2627 Cam Change Gasket kt
SUM-G2621 Rear Cover with Main Seal
SUM-150106 Cam Retainer Plate
ARP-134-1003 Cam Bolts
ARP 234-2503 Crank Bolt
TFS-30675540 Timing Chain damper
ARP-200-8683 Windage Tray Nuts
ARP-671-1002 Oil pump Bolts
ICB-551432 Timing Cover bolts
SUM ___ LS engine diaper
I plan to reuse my Holley 302-2 oil pan and Holley High Ram intake.
The block is over with Graham Jones @ FastTimes. He determined that we are good with a .005 over bore which was going to effect the piston selection.
I kicked back and forth staying stock crank but the one in the builder block was not usable so that was not even an option.
Again this is a parts list in progress, I'll note when it's been edited.
Old Apr 1, 2022 | 03:06 PM
theunderlord's Avatar
Very cool! Trying to stay within a certain $ budget or anything?
Old Apr 1, 2022 | 04:10 PM
LS1Tech Co-Founder
Yeah I'm not sure what the final tally would be, I plan to figure that out and share it at the end. I figured that Summit would be the best bet for prices and they carry quality stuff so I couldn't go wrong. There are better cylinder heads but they get really pricey.
Old Apr 1, 2022 | 04:23 PM
Makes sense!
Old Apr 1, 2022 | 04:45 PM
GMCGreg's Avatar
What's the power goal John ? What sort of cam specs? Just curious as it's probably over anything I'm prepared to do. Sounds pretty stout!!
Old Apr 1, 2022 | 04:48 PM
ddnspider's Avatar
Surprised your not going to give Summit a chance on the cam since the rest of the parts are from them. What's the boost coming from?
Old Apr 1, 2022 | 06:25 PM
LS1Tech Co-Founder
I'd like the longblock to support 1100rwhp reliably, I wanted to say 1200rwhp but I don't wantt to get out of control.
Right now the car has a billet wheel FIS BW 95/96 ddn.
Old Apr 3, 2022 | 11:36 PM
truckdoug's Avatar
i have had good luck with the btr small bore "ls9" head gasket
Old Apr 5, 2022 | 09:12 AM
C5_Pete's Avatar
John, has the builder brought up filling the block to the water holes? If not, I guess they believe the LC9 is capable of staying together at that level?
Seems quite impressive for an aluminum block… I have no first hand experience with the LC9, but we pushed an LSA to around 1200 crank.
Best of success to you!
Old Apr 6, 2022 | 03:02 PM
LS1Tech Co-Founder
Not planning to half or full fill the block.
Jon Capizzi has pushed an unfilled LC9 to 4.20s with safe tuning.
Old Apr 6, 2022 | 03:25 PM
3 window's Avatar
You plan on the same RPMs as him?
Old Apr 6, 2022 | 03:44 PM
LS1Tech Co-Founder
I don't plan to buzz mine higher than about 8000, and I don't have plans to run 4.20s'.
Old Apr 7, 2022 | 09:27 AM
C5_Pete's Avatar
Very cool John. Best of success with it!
Old Apr 7, 2022 | 09:30 AM
Black_Sunshine_99's Avatar
Yet.......
Old Apr 7, 2022 | 01:04 PM
LS1Tech Co-Founder
Supposedly my SBE and this planned built combo will run up over 8000 but I'm not at a point where I know what it wants.
Old Apr 7, 2022 | 10:01 PM
jayyyw's Avatar
Sounds like a solid build. Should work out great
Old Apr 8, 2022 | 10:23 AM
I'm gonna guess your turbo will need a bigger exhaust wheel to run efficiently up into the 8000+ rpm range.
Old Apr 8, 2022 | 01:20 PM
LS1Tech Co-Founder
The original owner of this 85/96 spun it over 8000 and did well with it (7.72@174, 2900 raceweight).
Old Apr 8, 2022 | 01:40 PM
Ah okay, I was think of Scott MacDonald who ran a 5.3 and saw some pretty significant gains by moving to the bigger exhaust wheel.
Can't wait to see some results!
Old Apr 22, 2022 | 02:28 PM
LS1Tech Co-Founder
Updated with more part numbers. Changed the pushrod part number to longer ones.
