E85 vs e98 fuel percent increase?
Old May 28, 2022 | 12:44 PM
Forcefed86's Avatar
Default E85 vs e98 fuel percent increase?
So i know its roughly 30-35% from gas to e85. Have the car dialed in on e85 now. Looking to switch to e98 to see if it helps my non-intercooled setup any. Anyone know roughly how much fuel to add on the map? Just looking for ball park.
I pick up good 5.5-6 mph from 10-16lbs or so... 16-20 i nose over pretty hard. IAT is 250 bybthe end of the run. Bud picked up quite a bit going from e85 to e98 on his hot air car.
Thanks.
Old May 28, 2022 | 01:04 PM
007FJ's Avatar
I too seek such knowledge!
Old May 28, 2022 | 03:59 PM
3 window's Avatar
It’s about 7.5% more fuel from E85
Old May 31, 2022 | 11:03 AM
SLOW SEDAN's Avatar
For the price of those fancy ethanol's, why not just run methanol at the track? Or convert it to blow thru, would look cool on that old car.
Old May 31, 2022 | 04:48 PM
Kawboom's Avatar
You would need a methanol safe fuel system, and flush the engine with gas afterwards. You can gain power, but may not be worth it for some.
Old May 31, 2022 | 04:50 PM
Kawboom's Avatar
by my math its more like 5% going from E85 to E98.
Old Jun 1, 2022 | 10:58 AM
Forcefed86's Avatar
I've now heard 5-15% lol. I have e98 at the pump a couple blocks from my house. Only reason I want to try is a bud picked up almost 200whp switching from C85 to E98 at our local pump. Same timing and boost. 1200ishwhp to almost 1400ish whp. IDK if C85 is that bad or what. He runs a gen4 mopar with twin bullseye 83s non-intercooled. Def don't expect that, but its almost no effort to test it for me personally. a 15% jump for me would be 90hp tho. that would be huge at my weight.
I don't have the fuel system for methanol and I drive to and from the track.
Old Jun 1, 2022 | 11:35 AM
SLOW SEDAN's Avatar
Gotcha, E98 that close is nice! Certainly worth a try at that point, buying the overpriced canned stuff not so much.
Old Jun 1, 2022 | 04:01 PM
NicD's Avatar
7 Second Club
You do realize that is literally impossible right? If boost and timing were left alone it's going to make nearly identical power with just a bit more ethanol content...
Old Jun 1, 2022 | 05:37 PM
3 window's Avatar
We had a buddy’s 1000hp 6.0 on an engine dyno and going from E85 to C85, with no changes to the tune picked up 25hp. So I’m with NicD on this one. I can’t see it picking up that much going to pump E98. I could be wrong though.
Note: That was at 1000 hp fwiw
Old Jun 1, 2022 | 07:56 PM
sr71's Avatar
talk to mark sullens @ mark sullens e85 carburetors. the man probably knows more about e85 fueling than anyone else. and his knowledge is backed up by time on the dyno and at the track. he says that there is no power to be had running e98 over e85. and that e87 is optimum. the ethanol makes the power but needs the 13%-15% gasoline to light the ethanol off. and that the cheap 87 octane fuel blended with the ethanol in e85 works best for that purpose. anyone can learn alot from talking to mark.
Old Jun 1, 2022 | 09:21 PM
LilJayV10's Avatar
I don't want to be that guy but....there's no way he picked up 200w going from E85 to E98.
Old Jun 1, 2022 | 09:34 PM
3 window's Avatar
Cheap 87 octane in E98? I math fairly good, but can’t see gettin E87 from cheap 87 and E85.
Old Jun 1, 2022 | 09:53 PM
badass68's Avatar
We did this on a 800rwhp zr1. Went from pump e85 to ignite e98 without touching timing. Picked up 6 hp.
Old Jun 2, 2022 | 02:12 AM
Kawboom's Avatar
The organic chemist in me is confused by this statement.
There may not be extra power to be made but the ethanol does not need gasoline to "light the ethanol off", what that bit of gasoline is doing is giving you a bit of oil to help lubricate your engine,
BTUs of heat produced x total gas molecules in the combusted material = cylinder pressure. Cylinder pressure + RPM = Horsepower. Add a small multiplier for increased efficiency due to running the most compression possible and you have your formula.
Old Jun 2, 2022 | 04:37 AM
sr71's Avatar
I am saying the gasoline part of pump e85 is just regular 87 octane. they tried ethanol blended with race gas to e85 proportions with no benefits. mark said thate87(13% gas and 87% ethanol) made the best power.
Old Jun 2, 2022 | 06:20 AM
BCNUL8R's Avatar
I’m factory ecu open loop with no flex fuel setup. When I change ethanol percentage I just change the stoich in the tune and my fueling is pretty much dead on.
For example I’m currently running 50 percent ethanol. I use this calculation to determine my stoich.
9 x (ethanol percentage) + 14.68 x (gas percentage) = stoich
So stoich for 50 percent ethanol is 11.84
When I switched from 70 percent to 50 percent to give my fuel system more room the stoich is all I changed and fueling fell right in place.
Old Jun 2, 2022 | 07:36 AM
Forcefed86's Avatar
I agree and don't think E98 is magically going to fix my problems or give me 200hp. But I was there! back to back pulls... drain fill E98. Had to add a ton of fuel at like boost and timing. Im sure not saying e98 is worth a 15% power increase over E85. All i'm saying is for *some reason* his setup hated C85 drum fuel and did much better on E98. A switch to pump E85 may have net similar gains. Or maybe the C85 needed ALOT more timing than they had in it. Who knows. Most I know that have run both fuels, aren't hot air cars either.
My reasoning for trying it is simply because its down the street and doesn't take much of a tune change. If I pick up anything notable or the plugs read cooler its a win. I go to the same gas station to fill up on E85 as I would for the E98.
Im seeing 250* charge temps now @ 20lbs on twin 78/75s' (mild SBE 5.3). So having 10-15% more fuel in the cylinder to help cool it seems like a good idea. 8 heat range plugs are half way down the strap at 14-15*. Really didn't want the additional hassle of an intercooler or meth injection. No room on a model T and figure I *should* be able to hit a 8.50 cage cert at 2400lbs race weight without it. Setup is down 200hp from where it should be IMO.
Still working the bugs out here.
https://ls1tech.com/forums/conversio...-turbo-16.html
Old Jun 3, 2022 | 01:04 PM
NicD's Avatar
7 Second Club
There was another variable outside of the fuel change. C85 is virtually no different then pump E85, etc and it doesn't tune any differently either. The benefits all the fancy E85/E98 fuels have over pump E85 is consistency and safety in the form of higher octane/better base fuels that are used when mixed with the ethanol portion. I run One R in my TT Z06 not because it's going to make more power with my conservative tune up but because it's super consistent, clean, and has an octane level that SHOULD help keep things safer if something else decides to **** up.
Old Jun 3, 2022 | 01:12 PM
Forcefed86's Avatar
Not saying there wasn't, only stating what I saw in person, on the only hot air car I've seen make the switch with a back to back test. He was running drum fuel for all the same reasons you mentioned. It was def a 1400hp setup and was down on power at 1200 for unknown reasons w C85.
